Hi Guys
SO I have the esp32 Lilygo, I hired a guy from fivver to write the code as I need to make it it's own hot spot.
I have inserted the t mobile sim card and I am able to see the hot spot name and connect. However no matter what It says connected with no internet. I have reached out to the one I hired and we have tried several things. He uploaded a code that allowed it to send a text to my other phone, But for some reason it still says no internet. Any suggestions?
The following is the code..
// Libraries which has to be installed
#define TINY_GSM_MODEM_SIM800 // Modem is SIM800 has to be defined before the Tiny-Include
#include <Wire.h>
#include <TinyGsmClient.h>
#include <WiFiClient.h>
#include <WiFi.h>
#include <WiFiServer.h>
// Variables and desired credentials.
const char *ssid = "Hotspot Name"; // Access Point - SSID (Name)
const char *password = "123456789"; // Access Point - Password
const int APPort = 8083; // Access Point - Port
// Your GPRS credentials (leave empty, if missing)
const char apn[] = "fast.t-mobile.com"; // GPRS - Your APN
const char gprsUser[] = ""; // GPRS - User
const char gprsPass[] = ""; // GPRS - Password
const char simPIN[] = "1503"; // GPRS - SIM card PIN code, if any
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
#define SerialMonitor Serial // Set serial for debug console to the Serial Monitor
#define SerialAT Serial1 // Set serial for AT commands (to the module)
#define TINY_GSM_RX_BUFFER 1024 // Set RX buffer to 1Kb
// #define TINY_GSM_DEBUG SerialMonitor // Define the serial console for debug prints
WiFiServer APserver(80); // neu für AP
TinyGsm modem(SerialAT);
TinyGsmClient Webclient(modem);
char server[] = "vsh.pp.ua"; // Server details of demo Website
// String resource = "/TinyGSM/logo.txt";
String resource = "/windows-version.txt";
const int port = 80; // Port if demo Website
#define IP5306_ADDR 0x75
#define IP5306_REG_SYS_CTL0 0x00
bool setPowerBoostKeepOn(int en)
Wire.beginTransmission(IP5306_ADDR);
Wire.write(IP5306_REG_SYS_CTL0);
if (en) {
Wire.write(0x37); // Set bit1: 1 enable 0 disable boost keep on
Wire.write(0x35); // 0x37 is default reg value
return Wire.endTransmission() == 0;
SerialMonitor.begin(115200); // Set console baud rate
SerialMonitor.println("Programm ESP32_TTGO_T_CALL_TinyGSM"); // Just to know which progm is running
delay(10);
WiFi.onEvent(WiFiEvent); // set event-handler for WiFi
WiFi.softAP(ssid, password); // define credentials
IPAddress myIP = WiFi.softAPIP(); // inform console about own IP-Adress
SerialMonitor.print("AccessPoint IP address: ");
SerialMonitor.println(myIP);
SerialMonitor.print(":");
SerialMonitor.print(APPort);
APserver.begin(APPort); // AccessPoint with defined Port
SerialMonitor.println("WiFi Server started");
// Keep power when running from battery
Wire.begin(I2C_SDA, I2C_SCL); // Workaround for Modem Power
bool isOk = setPowerBoostKeepOn(1);
SerialMonitor.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
pinMode(MODEM_PWKEY, OUTPUT); // Set-up modem reset, enable, power pins
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
// Set GSM module baud rate and UART pins
SerialAT.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(3000);
SerialMonitor.println("Initializing modem...");
// modem.restart(); // To skip it, call init() instead of restart()
modem.init(); // if you don't need the complete restart
String modemInfo = modem.getModemInfo();
SerialMonitor.print("ModemInfo: "); // inform console about Modem info
SerialMonitor.println(modemInfo);
// Unlock your SIM card with a PIN if needed
if (strlen(simPIN) && modem.getSimStatus() != 3 ) {
modem.simUnlock(simPIN);
SerialMonitor.print("Modemstatus: "); // inform console about Modem info
SerialMonitor.println(modem.getSimStatus());
// Wenn ein WLAN - Client mit dem AP verbunden ist
WiFiClient client = APserver.available(); // listen for incoming clients
if (client) { // if you get a client,
process(client); // Process request
delay(10);
client.stop(); // Close connection and free resources.
Serial.println("Client Disconnected.");
} // from if Client
} // from loop()
void process(WiFiClient client) {
Serial.println("New Session."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("HTTP/1.1 200 OK");
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("Klick <a href=\"/vsh.pp.ua\">here</a> to read sample page.<br>");
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
} else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// Check to see if the client request was "GET //vsh.pp.ua":
if (currentLine.endsWith(" HTTP/1.1")) {
// First line of HTTP request looks like "GET /path HTTP/1.1"
// Retrieve the "/path" part by finding the spaces or "/"
int addr_start = currentLine.indexOf(' ');
int addr_midl = currentLine.indexOf('/', addr_start + 2);
int addr_end = currentLine.indexOf('HTTP');
/* SerialMonitor.print("addr_start: ");
SerialMonitor.println(addr_start);
SerialMonitor.print("addr_midl: ");
SerialMonitor.println(addr_midl);
SerialMonitor.print("addr_end: ");
SerialMonitor.println(addr_end);
SerialMonitor.println();
SerialMonitor.print("currentLine: ");
SerialMonitor.println(currentLine); */
String req_server = currentLine.substring(addr_start + 2, addr_midl);
SerialMonitor.print("req_server.length(): ");
SerialMonitor.println(req_server.length());
SerialMonitor.println(req_server);
if (req_server.length() == 0) {
// No server defined -> Some Help
client.println();
client.print("Klick <a href=\"/vsh.pp.ua/TinyGSM/logo.txt\">here</a> um das Logo aufzurufen.<br>");
client.println();
String req_page = currentLine.substring(addr_midl, addr_end - 3);
strcpy(server, req_server.c_str());
resource = req_page;
SerialMonitor.print("resource: ");
SerialMonitor.println(resource);
SerialMonitor.print("Connecting to ");
SerialMonitor.print(server);
if (!Webclient.connect(server, port)) {
SerialMonitor.println(" fail");
delay(10000);
return;
SerialMonitor.println(" OK");
// Make a HTTP GET request:
SerialMonitor.println("Performing HTTP GET request...");
Webclient.print(String("GET ") + resource + " HTTP/1.1\r\n");
Webclient.print(String("Host: ") + server + "\r\n");
Webclient.print("Connection: close\r\n\r\n");
Webclient.println();
unsigned long timeout = millis();
while (Webclient.connected() && millis() - timeout < 10000L) {
// Print available data
while (Webclient.available()) {
char c = Webclient.read();
SerialMonitor.print(c);
client.print(c); // Ausgabe gleich auf den Client
timeout = millis();
// Verindung zum Web-Server abbauen
Webclient.stop();
SerialMonitor.println(F("Web-Server disconnected"));
void WiFiEvent(WiFiEvent_t event) {
// Handler of WIFI-Event
switch (event) {
case SYSTEM_EVENT_WIFI_READY:
Serial.println("SYSTEM_EVENT_WIFI_READY");
case SYSTEM_EVENT_SCAN_DONE:
Serial.println("SYSTEM_EVENT_SCAN_DONE");
case SYSTEM_EVENT_STA_START:
Serial.println("SYSTEM_EVENT_STA_START");
case SYSTEM_EVENT_STA_STOP:
Serial.println("SYSTEM_EVENT_STA_STOP");
case SYSTEM_EVENT_STA_CONNECTED://or STARTED ?
Serial.println("SYSTEM_EVENT_STA_CONNECTED");
case SYSTEM_EVENT_STA_DISCONNECTED:
Serial.println("SYSTEM_EVENT_STA_DISCONNECTED");
case SYSTEM_EVENT_STA_AUTHMODE_CHANGE:
Serial.println("SYSTEM_EVENT_STA_AUTHMODE_CHANGE");
case SYSTEM_EVENT_STA_GOT_IP:
Serial.println("SYSTEM_EVENT_STA_GOT_IP");
case SYSTEM_EVENT_STA_LOST_IP:
Serial.println("SYSTEM_EVENT_STA_LOST_IP");
case SYSTEM_EVENT_AP_START:
Serial.println("SYSTEM_EVENT_AP_START");
case SYSTEM_EVENT_AP_STOP:
Serial.println("SYSTEM_EVENT_AP_STOP");
case SYSTEM_EVENT_AP_STACONNECTED:
Serial.println("SYSTEM_EVENT_AP_STACONNECTED");
case SYSTEM_EVENT_AP_STADISCONNECTED:
Serial.println("SYSTEM_EVENT_AP_STADISCONNECTED");
modem.gprsDisconnect();
SerialMonitor.println(F("GPRS disconnected"));
// Do nothing forevermore
SerialMonitor.println("www.thingsmobile.com user lora@felmayer.de");
case SYSTEM_EVENT_AP_STAIPASSIGNED:
Serial.println("SYSTEM_EVENT_AP_STAIPASSIGNED");
// wenn eine WLAN-Verbindung aufgebaut ist !!!
// Netzwerk initialisieren und Modem tiiii tööööö ti tit ti so wie bei alten Modem 14400 ...
SerialMonitor.print("Waiting for network...");
if (!modem.waitForNetwork(240000L)) {
delay(10000);
return;
if (modem.isNetworkConnected()) {
SerialMonitor.println("Network connected");
SerialMonitor.print(F("Connecting to APN: "));
SerialMonitor.print(apn);
if (!modem.gprsConnect(apn, gprsUser, gprsPass)) {
delay(10000);
return;
case SYSTEM_EVENT_AP_PROBEREQRECVED:
Serial.println("SYSTEM_EVENT_AP_PROBEREQRECVED");
default:
Serial.println("UNKNOWN EVENT: " + event);
Esp32 Lilygo Hotspot. No Internet
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- 全国大学生物联网设计竞赛乐鑫答疑专区
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
Users browsing this forum: No registered users and 109 guests
- All times are UTC
- Top
- Delete cookies
About Us
