how to SET esp_timer_get_time() ?
cyberman54
Postby cyberman54 » Thu Dec 10, 2020 2:31 pm
I am using a time critial library (MCCI LMIC), that depends on micros() as monotonic time base. In arduino-esp32 micros() is hardwired to esp_timer_get_time(), which does not persist it's counter value during deep sleep. Thus micros() cannot act as a monotonic counter after waking up from sleep.
https://github.com/espressif/arduino-es ... isc.c#L134
unsigned long IRAM_ATTR micros()
    return (unsigned long) (esp_timer_get_time());
How can i solve this, without hacking the library?
Is there a way to add an offset by app to esp_timer_get_time()?
- Perhaps by using a wake stub, which adds a sleep time offset immediately after wake up?
- Or is there a way to overwite the micros() function of arduino-esp32 with a customized version?
lbernstone
Re: how to SET esp_timer_get_time() ?
Postby lbernstone » Thu Dec 10, 2020 3:40 pm
The rtc clock will run through deep sleep if the rtc power domain is on. Note that the following example shows ticks, not usec. https://github.com/espressif/esp-idf/bl ... rtc.h#L524
#include <soc/rtc.h>
  Serial.printf("rtc_time: %d", rtc_time_get());
  Serial.flush();
  esp_sleep_enable_timer_wakeup(5000000ULL);
  esp_deep_sleep_start();
void loop() {}
cyberman54
Postby cyberman54 » Thu Dec 10, 2020 8:08 pm
Thanks for this hint!
But how can i bind micros() or millis() in arduino-esp32 to RTC clock?
Users browsing this forum: No registered users and 54 guests
