ESP32 board not connecting to Wifi
maxipoblete
Postby maxipoblete » Sun Apr 12, 2020 6:06 pm
Hello i can't get my adafruit esp32 feather board to connect the WIFI . I open the serial monitor but it keeps saying "connecting to wifi". My SSID and password are corrrect, i dont know what to do because i achieved to connect it like 2 hours ago and now i have this problem
here is my code
  Rui Santos
  Complete project details at https://randomnerdtutorials.com
#include <ESPAsyncWebServer.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <WiFi.h>
#include <Wire.h>
#include <AsyncTCP.h>
const char* ssid = "NET20";
const char* password = "A3c2a12020";
#define DHTPIN A0     // Digital pin connected to the DHT sensor
// Uncomment the type of sensor in use:
#define DHTTYPE    DHT11     // DHT 11
//#define DHTTYPE    DHT22     // DHT 22 (AM2302)
//#define DHTTYPE    DHT21     // DHT 21 (AM2301)
DHT dht(DHTPIN, DHTTYPE);
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
String readDHTTemperature() {
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  //float t = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(t)) {
    Serial.println("Failed to read from DHT sensor!");
    return "--";
  else {
    Serial.println(t);
    return String(t);
String readDHTHumidity() {
  float h = dht.readHumidity();
  if (isnan(h)) {
    return "--";
  else {
    Serial.println(h);
    return String(h);
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
  <meta name="viewport" content="width=device-width, initial-scale=1">
  <link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
  <style>
    html {
     font-family: Arial;
     display: inline-block;
     margin: 0px auto;
     text-align: center;
    h2 { font-size: 3.0rem; }
    p { font-size: 3.0rem; }
    .units { font-size: 1.2rem; }
    .dht-labels{
      font-size: 1.5rem;
      vertical-align:middle;
      padding-bottom: 15px;
  </style>
</head>
<body>
  <h2>ESP32 DHT Server</h2>
  <p>
    <i class="fas fa-thermometer-half" style="color:#059e8a;"></i>
    <span class="dht-labels">Temperature</span>
    <span id="temperature">%TEMPERATURE%</span>
    <sup class="units">&deg;C</sup>
  </p>
  <p>
    <i class="fas fa-tint" style="color:#00add6;"></i>
    <span class="dht-labels">Humidity</span>
    <span id="humidity">%HUMIDITY%</span>
    <sup class="units">%</sup>
  </p>
</body>
<script>
setInterval(function ( ) {
  var xhttp = new XMLHttpRequest();
  xhttp.onreadystatechange = function() {
    if (this.readyState == 4 && this.status == 200) {
      document.getElementById("temperature").innerHTML = this.responseText;
  xhttp.open("GET", "/temperature", true);
  xhttp.send();
}, 10000 ) ;
      document.getElementById("humidity").innerHTML = this.responseText;
  xhttp.open("GET", "/humidity", true);
  xhttp.send();
}, 10000 ) ;
</script>
</html>)rawliteral";
// Replaces placeholder with DHT values
String processor(const String& var){
  //Serial.println(var);
  if(var == "TEMPERATURE"){
    return readDHTTemperature();
  else if(var == "HUMIDITY"){
    return readDHTHumidity();
  return String();
void setup(){
  // Serial port for debugging purposes
  dht.begin();
  // Connect to Wi-Fi
  WiFi.begin(ssid, password);
  WiFi.setSleep(false);
    delay(500);
    Serial.println("Connecting to WiFi..");
  // Print ESP32 Local IP Address
  Serial.println("");
  Serial.println("Successfully connected to WiFi.");
  Serial.println("IP address of ESP32 is : ");
  // Route for root / web page
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/html", index_html, processor);
  server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readDHTTemperature().c_str());
  server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
    request->send_P(200, "text/plain", readDHTHumidity().c_str());
  // Start server
  server.begin();
void loop(){
Anyone know what i should do?
fasani
Contact:
Re: ESP32 board not connecting to Wifi
Postby fasani » Fri Apr 17, 2020 5:52 am
What I would recommend to do first is to start from zero, just with a WiFi connect example and see if that works.
So actually quite an empty sketch with nothing on the loop() and just the WiFi library and this 3 or 4 lines to connect to WiFi. I guess if you are using Arduino you have a WiFi example ready to modify and compile.
Add also the Serial output so we can see what you get.
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Users browsing this forum: No registered users and 87 guests
