Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
NOPE123
Postby NOPE123 » Fri Mar 20, 2020 12:09 pm
I'm trying to reset some NVS data with a press of a button. As soon as the ISR runs, the system reboots.
Here's the short code, what could be the cause, how to solve?
#include <Preferences.h>
#include <Arduino.h>
#define RESET_BUTTON 23
void IRAM_ATTR reset_isr(){
  Preferences pref;
  pref.begin("wifidata");
  pref.remove("st_ssid");
  pref.remove("st_password");
  pref.end();
  Serial.println("Credientials removed!");
  pinMode(RESET_BUTTON, INPUT_PULLUP);
  attachInterrupt(digitalPinToInterrupt(RESET_BUTTON), reset_isr, RISING);
ESP_Sprite
Re: Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
Postby ESP_Sprite » Sun Mar 22, 2020 12:21 pm
Don't do complex stuff like that in an ISR. Set a variable (or better: use a semaphore) and check for that once you're not in the ISR anymore (e.g. in the main loop).
Users browsing this forum: No registered users and 49 guests
