Simple Semaphore as task delay with interrupt
Insomniac
Postby Insomniac » Fri Feb 21, 2020 11:00 pm
I´m using a vTaskDelay right now to suspend my task for a while, but not being able to unblock before time runs up is a problem.
After reading a while, it seems a binary semaphore is a good solution. I have taken a look on the example of xSemaphoreGiveFromISR
https://www.freertos.org/a00124.html
, which seems to be a bit more then I need. I now deleted everything not necessary (from what I can say), but as I am not familiar with semaphores, I´d like to get a feedback if there could be a problem the way I handled it:
#include <Arduino.h>
#define LONG_TIME 5000
SemaphoreHandle_t xSemaphore = NULL;
void vATask( void * pvParameters );
    xTaskCreate(vATask, "vATask Loop", 1000, NULL, 1, NULL);
  delay(1000);
  /* if (xSemaphore != NULL)
    xSemaphoreGiveFromISR( xSemaphore, NULL ); */
    xSemaphore = xSemaphoreCreateBinary();
    while(1)
        Serial.println("Begin Loop");
        xSemaphoreTake( xSemaphore, LONG_TIME );
        Serial.println("End Loop");
void vTimerISR( void * pvParameters )
    portYIELD_FROM_ISR();
As said before, all I need is a delay of a task, with the option to unblock before (which seems to work fine when uncommenting the loop code).
ESP_Sprite
Re: Simple Semaphore as task delay with interrupt
Postby ESP_Sprite » Mon Feb 24, 2020 11:41 am
That should work (given you uncomment the two lines in loop()). Two things of note:
- vTimerISR is unused in your code, and
- xSemaphoreGiveFromISR will work but is more useful for use in interrupt handlers. If you're not in an interrupt handler (ISR) you can use xSemaphoreGive instead.
Users browsing this forum: No registered users and 30 guests
