espnow wifi channel setup changed?
Posted: Fri Nov 01, 2019 11:39 am
arduino-esp32 1.0.4
Arduino ide 1.8.10
esp32: WEMOS D1 MINI ESP32 plus LOLIN D32
Having used espnow with an earlier arduino-esp32 release, it was sufficient to do:
However, as I tried this using arduino-esp32 1.0.4 it did not work.
Looking through the error messages and the documentation, I found a solution.
I wanted to let the slave search for the master by changing channel
until a succesfull send response was received.
Using the esp_wifi_set_promiscuous call, I succeded like:
Is there an easier or better solution to do this?
Does it have any side effects ?
I have two simple, quickly put together sketches to illustrate how a slave can search
for the master (intended to be connected to a local lan ) looping through
the channels.
It is very crude, basic test programs just to show how to find the master on a specific channel.
The slave tries to send a token to the master after each channel change and stop when a response
is received.
Then it continues to send to the master using the found channel.
Here is the slave code used to test the search for master:
And the master test code:
Arduino ide 1.8.10
WiFi.mode(WIFI_STA);
WiFi.disconnect();
uint8_t primaryChan = 6;
wifi_second_chan_t secondChan = WIFI_SECOND_CHAN_NONE;
esp_wifi_set_channel(primaryChan, secondChan);
if (esp_now_init() == ESP_OK)
ESP_ERROR_CHECK(esp_wifi_set_promiscuous(true));
ESP_ERROR_CHECK(esp_wifi_set_promiscuous(false));
WiFi.disconnect();
the channels.
is received.
esp32now slave
#include <esp_now.h>
#include <WiFi.h>
#include <esp_wifi.h>
#define HIGHEST_CHANNEL 11
#define LOWEST_CHANNEL 1
#define FIXED_CHANNEL 6
//#define USE_FIXED_CHANNEL //Uncomment for no channel search
//Use custom MAC for both master and slave
uint8_t masterDeviceMac[] = {0xB4, 0xE6, 0x2D, 0xE9, 0xFE, 0x6E};
uint8_t CustomMac[] = {0x3C, 0x71, 0xBF, 0x03, 0x3D, 0x30};
esp_now_peer_info_t master;
const esp_now_peer_info_t *masterNode = &master;
esp_err_t sendResult;
const uint8_t maxDataFrameSize = 200;
uint8_t dataToSend[maxDataFrameSize];
byte cnt = 0;
int dataSent = 0;
int wifi_channel = 1;
int ms_sleep = 0;
void WiFiReset() {
WiFi.persistent(false);
WiFi.disconnect();
WiFi.mode(WIFI_OFF);
delay(100);
void setup()
Serial.begin(115200);
Serial.print("\r\n\r\n");
#ifdef USE_FIXED_CHANNEL
uint8_t primaryChan = FIXED_CHANNEL;
#else
for (uint8_t primaryChan = LOWEST_CHANNEL; primaryChan <= HIGHEST_CHANNEL; primaryChan++) {
#endif
WiFiReset();
delay(100);
esp_wifi_set_mac(ESP_IF_WIFI_STA, &CustomMac[0]);
delay(250);
Serial.print("Channel no: ");
Serial.println(primaryChan);
Serial.println( WiFi.macAddress() );
ESP_ERROR_CHECK(esp_wifi_set_channel(primaryChan, secondChan));
WiFi.printDiag(Serial);
WiFi.disconnect();
Serial.print("Wifi Channel: "); Serial.println(WiFi.channel());
Serial.println("ESP NOW INIT!");
else
Serial.println("ESP NOW INIT FAILED....");
memcpy( &master.peer_addr, masterDeviceMac, 6 );
master.channel = primaryChan;
master.encrypt = 0;
master.ifidx = ESP_IF_WIFI_STA;
if ( esp_now_add_peer(masterNode) == ESP_OK)
Serial.println("Added Peer!");
#else
//Add node irst time, else replace
if (primaryChan == LOWEST_CHANNEL) {
} else {
if (esp_now_mod_peer(masterNode) == ESP_OK)
Serial.println("Modified Peer!");
#endif
esp_now_register_send_cb(OnDataSent);
esp_now_register_recv_cb(OnDataRecv);
dataSent = 0;
//Send test data
if ( TestSend() ) {
//Wait for data sent confirmed
for (int i = 0; i < 1000; i++, ms_sleep--) {
delay(1);
yield();
if (dataSent != 0 ) {
break; //No data sent, try another channel
if (dataSent == 1 ) {
//Save channel to nvr/RTC mem ?
Serial.printf("Found Master on channel: %d\n", WiFi.channel());
#ifndef USE_FIXED_CHANNEL
break;
#endif
delay(500);
#endif
void loop()
for (cnt = 0; cnt < maxDataFrameSize; cnt++)
dataToSend[cnt]++;
esp_err_t sendResult = esp_now_send(master.peer_addr, dataToSend, sizeof(dataToSend)); //maxDataFrameSize);
if (sendResult == ESP_OK) {
Serial.println("Success");
} else if (sendResult == ESP_ERR_ESPNOW_NOT_INIT) {
// How did we get so far!!
Serial.println("ESPNOW not Init.");
} else if (sendResult == ESP_ERR_ESPNOW_ARG) {
Serial.println("Invalid Argument");
} else if (sendResult == ESP_ERR_ESPNOW_INTERNAL) {
Serial.println("Internal Error");
} else if (sendResult == ESP_ERR_ESPNOW_NO_MEM) {
Serial.println("ESP_ERR_ESPNOW_NO_MEM");
} else if (sendResult == ESP_ERR_ESPNOW_NOT_FOUND) {
Serial.println("Peer not found.");
else if (sendResult == ESP_ERR_ESPNOW_IF) {
Serial.println("Interface Error.");
} else {
Serial.printf("\r\nNot sure what happened\t%d", sendResult);
delay(1500);
int TestSend() {
strcpy((char*)dataToSend, "Calling Master");
return 1;
} else {
return 0;
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
dataSent = (status == ESP_NOW_SEND_SUCCESS ? 1 : -1);
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *data, int data_len)
//Serial.printf("\r\nReceived\t%d Bytes\t%d\n", data_len, data[0]);
Serial.printf("\r\nReceived\t%d Bytes\t%s\n", data_len, data);
espnow master
#include <WiFi.h>
#define WIFI_CHANNEL 10
uint8_t CustomMac[] = {0xB4, 0xE6, 0x2D, 0xE9, 0xFE, 0x6E};
uint8_t slaveDeviceMac[] = {0x3C, 0x71, 0xBF, 0x03, 0x3D, 0x30};
const byte maxDataFrameSize = 200;
byte cnt = 0;
int dataSent = 0;
esp_now_peer_info_t slave;
const esp_now_peer_info_t *peer = &slave;
void WiFiReset() {
WiFi.disconnect();
void setup()
WiFiReset();
WiFi.mode(WIFI_AP_STA );
Serial.print("Connecting to ");
Serial.println( WiFi.softAPmacAddress() );
//Force espnow to use a specific channel
WiFi.disconnect();
Serial.println("ESPNow Init Success!");
else
Serial.println("ESPNow Init Failed....");
//Add the slave node to this master node
memcpy( &slave.peer_addr, &slaveDeviceMac[0], 6 );
slave.channel = FIXED_CHANNEL;
slave.encrypt = 0;
slave.ifidx = ESP_IF_WIFI_STA;
if ( esp_now_add_peer(peer) == ESP_OK)
void prntmac(const uint8_t *mac_addr) {
Serial.print("MAC Address: {0x");
for (byte i = 0; i < 6; ++i) {
Serial.print(mac_addr[i], HEX);
if (i < 5)
Serial.print(",0x");
Serial.println("};");
void loop()
yield();
if (strncmp((const char *)data, "Calling Master",14) == 0 ) {
strcpy((char*)dataToSend, "Greeting from Master");
esp_err_t sendResult = esp_now_send(slave.peer_addr, dataToSend,sizeof(dataToSend)); // maxDataFrameSize);
Serial.print("Success delivering response");
} else {
} else {
Serial.print("Data sent to ");
prntmac(mac_addr);
dataSent = 1; //Sent executed
