Error occurred: Failed to connect to ESP32: Invalid head of packet ('S')
Posted: Wed Jun 19, 2019 5:50 am
Hardware:
Board: ?esp32-https://store.ncd.io/product/esp32-iot- ... rated-usb/
IDE name: ?Arduino IDE?
Flash Frequency: ?40Mhz?
Upload Speed: ?115200?
Description:
I am trying to connect Esp32 got this error "A fatal error occurred: Failed to connect to ESP32: Invalid head of packet ('S')". I tried to change upload speed or the flash frequency, but nothing work.
What can i do ?
Sketch:
* This sketch demonstrates how to scan WiFi networks.
* The API is almost the same as with the WiFi Shield library,
* the most obvious difference being the different file you need to include:
Description:
What can i do ?
Sketch:
#include "WiFi.h"
void setup()
Serial.begin(115200);
// Set WiFi to station mode and disconnect from an AP if it was previously connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
Serial.println("Setup done");
void loop()
Serial.println("scan start");
// WiFi.scanNetworks will return the number of networks found
int n = WiFi.scanNetworks();
Serial.println("scan done");
if (n == 0) {
Serial.println("no networks found");
} else {
Serial.print(n);
Serial.println(" networks found");
for (int i = 0; i < n; ++i) {
// Print SSID and RSSI for each network found
Serial.print(i + 1);
Serial.print(": ");
Serial.print(WiFi.SSID(i));
Serial.print(" (");
Serial.print(WiFi.RSSI(i));
Serial.print(")");
Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
delay(10);
Serial.println("");
// Wait a bit before scanning again
delay(5000);
