How to use U2UXD (Serial2)?
DrFilip
Postby DrFilip » Fri May 24, 2019 7:24 pm
I'm using ESP32-WROOM ver 1 with Arduino IDE.
I want to use the Serial2 (U2UXD) to connect a LoRa module in order to TX and RX messages.
I checked the pinout of the ESP32 board and saw that Serial2 corresponds to 17 and 16 pins, in which i connected the LoRa RX and TX, accordingly.
While i am using the next code, nothing is sent to pin 17.
Instead, if i connect the LoRa RX and TX to pin 41 and 40 (which is the U0UXD ... TX0 and RX0 --> Serial), the same code works fine.
However, i need UoUXD to be free, for other use.
#include <HardwareSerial.h>
#define RXD2 16 //RXX2 pin
#define TXD2 17 //TX2 pin
  Serial2.begin(115200, SERIAL_8N1, RXD2, TXD2);
    Serial.println("Hello1");
    Serial2.println(Hello2);
Could anybody help me?
Thank you a lot.
Users browsing this forum: No registered users and 74 guests
