Can not connect wifi with my second ESP32
oguzmuay
Postby oguzmuay » Fri Aug 13, 2021 4:59 am
I can connect to wifi with my first esp32, but not to the same wifi with my second esp32. I'm not trying to connect at the same time and the second esp32 can connect to other networks. I tried it with my phone's hotspot and it connected. I'm using the wifi client example.
ESP_Minatel
Re: Can not connect wifi with my second ESP32
Postby ESP_Minatel » Mon Aug 16, 2021 10:39 am
Can you check if you have any logging on your router? I've seen some cases that the router blocks due some pre-defined rules or some security configuration.
oguzmuay
Postby oguzmuay » Sat Aug 21, 2021 2:38 am
Thank you for your feedback. I replied a little late, but as far as I looked at the router, there is no security setting. There is no logging or any history view tab.
ESP_Minatel
Postby ESP_Minatel » Wed Aug 25, 2021 9:10 am
This is odd.
Have you tried on a different router?
oguzmuay
Postby oguzmuay » Tue Sep 14, 2021 9:18 pm
This is odd.
I tried with a different router, but after two or three attempts, only one of them connected after a long time. Thanks for trying to help.
Users browsing this forum: Google [Bot] and 75 guests
