ESP32 + 3.5' TFT LCD Panel OpenSmart
FloppyEggplant
Postby FloppyEggplant » Sun Jun 20, 2021 3:20 pm
I'm trying to connect an OpenSmart TFT LCD Panel (HX8357) to an ESP32 38 Pins (ESP32-D0WDQ6 Rev 1). When I use an Arduino, everything works fine (although slow and that is why I'm trying with an ESP32). The problem starts when I try to compile the program and it gives me an error avr/io.h not found.
I copied the avr library from the Arduino Library and now it shows me errors about things not declared on scope. I don't understand why as those are declared with #define CS_PIN 3.
The library that it is throwing errors is mcufriend inside the OPENSMART_TFT folder.
How can I make this work?
I've added 3 attachments:
  1. Schematics
  2. ino file with the code,
  3. Libraries
showBMP_kbv_as7_alt.7z
Code - Arduino File
(2.84 KiB) Downloaded 306 times
Schematics
libraries.7z
Libraries in Documents/Arduino/libraries
(1.55 MiB) Downloaded 287 times
Re: ESP32 + 3.5' TFT LCD Panel OpenSmart
Postby ESP_Sprite » Mon Jun 21, 2021 1:13 am
Looks like that library is specifically coded against the Microchip/Atmel AVR series of microcontrollers; the ESP32 is not one of those. Try using another library that is more generically set up instead.
Users browsing this forum: No registered users and 90 guests
