Wakeup mode
MuchMore
Wakeup mode
Postby MuchMore » Fri Mar 23, 2018 9:27 pm
I would need to the chip to wakeup on LOW on three seperat pins.
Defining three esp_sleep_enable_ext0_wakeup does not work.
And using a Bitmask and esp_sleep_enable_ext1_wakeup only gives me two options:
typedef enum {
    ESP_EXT1_WAKEUP_ALL_LOW = 0,    //!< Wake the chip when all selected GPIOs go low
    ESP_EXT1_WAKEUP_ANY_HIGH = 1    //!< Wake the chip when any of the selected GPIOs go high
} esp_sleep_ext1_wakeup_mode_t;
I would need "ESP_EXT1_WAKEUP_ANY_LOW".
Is this technical not possible or was this just omitted??
Haldi4803
Re: Wakeup mode
Postby Haldi4803 » Sun May 16, 2021 9:07 am
3 Years later i have the exact same question.
My Buttons are default HIGH and i want to wake up the device if any of the 3 Buttons is pressed.
Using Pin 34, 35 and 39.
There is no way to inverse the pins in Deep Sleep is there?
Archibald
Re: Wakeup mode
Postby Archibald » Sun May 16, 2021 10:04 am
Consider inverting electronically. The CD4049 CMOS integrated circuit has maximum quiescent current of 1μA, typically 0.02μA.
Users browsing this forum: No registered users and 42 guests
