load root CA from SPIFFS and pass to WiFiClientSecure
KevinHunter
Postby KevinHunter » Mon Oct 01, 2018 8:20 am
Hi all,
Im still a newbie and Im trying no move working code I wrote for the ESP8266 to the ESP32 but its not working.
I have a root certificate that I have stored in SPIFFS and I want to pass it to WifiClientSecure. On the ESP8266 I do it this way (which works):
  // Load CA file from SPIFFS
  File ca = SPIFFS.open("/site.cer", "r");
  if (!ca) {
    Serial.println("Failed to open ca ");
  else
    Serial.println("Success to open ca");
  delay(1000);
  // Set server CA file
  if (wifiClient.loadCACert(ca))
    Serial.println("ca loaded");
  else
    Serial.println("ca failed");
My first problem was that loadCACert() isnt supported by WiFiClientSecure on the ESP32 so I changed it to setCACert(). The problem I have now is that when I pass the file into this method ( wifiClient.setCACert(ca);) i get the following error:
no suitable conversion function from "fs::File" to "const char *" exists
So my question is , how do I convert a File to a const char ??
Kev
spestano
Re: load root CA from SPIFFS and pass to WiFiClientSecure
Postby spestano » Tue Oct 09, 2018 12:35 am
Try, reading your "ca" and store it in a buffer of type char then pass that buffer in your function.
xmoulin
Postby xmoulin » Wed Feb 17, 2021 6:03 pm
I have the same issue... Do you solve your problem?
kfine100
Postby kfine100 » Thu May 13, 2021 8:13 am
I do this with the ESP32. Spestano is correct, you just have to load into a buffer. To give you an example, I define
char myCertificate[N_BYTES_CERTIFICATE];
where N_BYTES_CERTIFICATE needs to be about 1500, and then read and load the certificate like this
myFServer.read2String(SPIFFS, REMOTE_CERT_FILE, myCertificate);
 //Serial.printf("\n%s\n", myCertificate);
 http_client_Secure.setCACert(myCertificate);
myFServer is just a class I created using SPIFFS.h and FS.h. The relevant read2String function is this:
void fServices::read2String(fs::FS &fs, const char * path, char *myString){
    File file = fs.open(path);
    if(!file || file.isDirectory()){
        return;
    int iChar = 0;
    while(file.available()){
      myString[iChar] = file.read();
      iChar++;
    file.close();
Hope this helps.
Users browsing this forum: Bing [Bot] and 49 guests
