WS2815 and ESP32
geeky121
WS2815 and ESP32
Postby geeky121 » Wed Sep 16, 2020 1:12 am
Hello!
I am having an issue with the ESP32-PoE-ISO by Olimex and 6 strips of 420 WS2815 addressable LEDs.
Background
I have these strips hooked up to a 12v 50amp power supply and they are connected to pins 2,3,32,33,14,15. I am using the FastLED library to control them and the esp32 is running off of PoE. it is grounded straight to each strip.
Problem
The issue I am having is flickering of strips, and when pin 2 or/and 4 are connected plus any other pin, pins 2 and 4 go crazy (flashing random colors, etc.) but when just 2 or/and 4 are connected I usually get mostly good results with just some flickering.
Things I've tried...
I have tried several several things now...
  1. I've added the lines "#FASTLED_ALLOW_INTERRUPTS 0" and "#FASTLED_INTERRUPT_RETRY_COUNT 0"
  • Completely removing all Ethernet code
  • Updating each strip separately
  • Logic Level Conversion
  • With and Without capacitor on power line and resistor on data line
*EDIT* there was a weird glitch where it deleted the ending of my post. I editted it and will be re-uploading the code.
Miraculix
Re: WS2815 and ESP32
Postby Miraculix » Wed Sep 16, 2020 10:07 am
Did you add a 1000uF electrolytic capacitor to each strip? If not, try it. Often this helps with WS2812B, so it may help with these strips too.
Postby ESP_Sprite » Wed Sep 16, 2020 10:44 am
Are you doing any level conversion between the ESP32 and the WS2815? The ESP32 is 3.3V while (according to what I read) the WS2815 expects 5V logic levels.
geeky121
Postby geeky121 » Wed Sep 16, 2020 12:18 pm
Yep, tried a few different sizes too. I've used the WS2812B strips in several other applications with no issues. I thought the WS2815's would be the same.. but they sure aren't acting like it!
Users browsing this forum: No registered users and 85 guests
