Hey guys,
after a little research why some of my requests end in an error I thought there might be a "best practice" to send multiple GET-requests in a short while (with library HTTPClient).
My basics: After I had a little problem with Cloudflare blocking my Vodafone home static IP address I added a delay for sending the requests. I collect up to 30 requests in an array and after a random delay for each request (between 1 and 10 seconds) I send every single request.
Some requests instantly work properly (code 200), some end in an error (-11). The requests themself are okay because after the 2nd / 3rd try the same "faulty" requests get also a 200.
Now I saw that -11 means HTTPC_ERROR_READ_TIMEOUT. Those requests take longer as I can see via Serial.print().
Could I solve this -11 problematic by using http.setReuse(true)? Does someone have a better idea how to improve that and prevent failing of sending some requests?
Intention (besides my "perfectionism" [as perfect I can act as a absolute beginner): At the same time a water pump could run which is controlled by time - if the requests take longer than expected the pump also runs longer which could cause some flooding in my living room....
Best practice sending multiple HTTP GET requests
Users browsing this forum: AnselmeC, lbernstone and 30 guests
