i am building a "digital twin" of an LEGO technic Hub, by using an ESP32.
Target is that ESP32 can be connected to LEGO BLE Apps.
At least i have concerns, that one reason i did not get a connecteion request is because LEGO Apps using Address Filters .
An Example of a LEGO HUB Adress is like:Advertising Address: LegoSyst_4a:3a:0c (90:84:2b:4a:3a:0c) ( a hub owned by me)
As you may know ours is like: Advertising Address: Espressi_cb:69:fa (bc:dd:c2:cb:69:fa)
Question is, how to change Advertising address is scetch to be shown as "LegoSyste" like : 90:84:2b:aa:bb:cc for example
Thanks in advance
Marc
Using a custom Advertising Address
Re: Using a custom Advertising Address
Start with this:
https://maclookup.app/macaddress/90842B
As you can see this is part of mac addresses registered by LEGO System A/S, and here is espressif:
https://maclookup.app/vendors/espressif-inc
I dont remember now if you can set particular bluetooth mac with IDF API, but its not possible with arduino library.
"but its not possible with arduino library."
It was solved by another helping hand:
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleServer.cpp
Ported to Arduino ESP32 by Evandro Copercini
updates by chegewara
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
// Set your new MAC Address
uint8_t newMACAddress[] = {0x90, 0x84, 0x2B, 0x4A, 0x3A, 0x0A};
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID "beb5483e-36e1-4688-b7f5-ea07361b26a8"
void setup() {
Serial.begin(115200);
Serial.println("Starting BLE work!");
esp_base_mac_addr_set(&newMACAddress[0]);
BLEDevice::init("Long name works now");
BLEServer *pServer = BLEDevice::createServer();
BLEService *pService = pServer->createService(SERVICE_UUID);
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ |
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setValue("Hello World says Neil");
pService->start();
// BLEAdvertising *pAdvertising = pServer->getAdvertising(); // this still is working for backward compatibility
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(true);
pAdvertising->setMinPreferred(0x06); // functions that help with iPhone connections issue
pAdvertising->setMinPreferred(0x12);
BLEDevice::startAdvertising();
Serial.println("Characteristic defined! Now you can read it in your phone!");
void loop() {
delay(2000);
Users browsing this forum: Google [Bot], lbernstone and 124 guests
