How to use LittleFS on ESP32?
sblantipodi
Postby sblantipodi » Sun Jun 14, 2020 4:05 pm
LittleFS became the standard on ESP8266 and is really convenient way to write data (even JSON) on the storage, without the ancient method needed when using EEPROM for example.
Is there a way to use LittleFS on ESP32? Or, does ESP32 have a good alternative to LittleFS?
idahowalker
Re: How to use LittleFS on ESP32?
Postby idahowalker » Sun Jun 14, 2020 7:51 pm
sblantipodi
Postby sblantipodi » Sun Jun 14, 2020 7:59 pm
https://docs.espressif.com/projects/esp ... index.html see Storage.
your answer does not really answer my question :)
bnp117
Postby bnp117 » Tue Jun 16, 2020 3:30 pm
Here's my port of LittleFS that has the same API as the esp-idf SPIFFS port. Basically it should just work if you replace all your "spiffs" calls with "littlefs". Only slight difference is in your configuration, you don't specify "max_files".
https://github.com/joltwallet/esp_littlefs
Users browsing this forum: No registered users and 45 guests
