ESP32-cam with ds1302?
Chuma87
Postby Chuma87 » Sun Jan 26, 2020 6:41 pm
Hello partners. I would like to know if an RTC module DS1302 can be connected to esp32cam. GPIO13 already in use, what other pins can I use for CLK, DAT and RST?
DS1302 rtc(GPIO_NUM_2,GPIO_NUM_12,GPIO_NUM_15);
it doesn't let me use GPIO4 because FLAsh is already using it
pipi61
Re: ESP32-cam with ds1302?
Postby pipi61 » Mon Jan 27, 2020 5:23 pm
If you do not use the sd card, then this pins available
Check the esp32 schematic...
Chuma87
Postby Chuma87 » Mon Feb 03, 2020 2:51 am
pipi61 wrote: If you do not use the sd card, then this pins available
But if I use SD later, can it?
In this link the DS1302 is avaiable for ESP32
#include <ErriezDS1302.h>
// Connect DS1302 data pin to Arduino DIGITAL pin
#if defined(ARDUINO_ARCH_AVR)
#define DS1302_CLK_PIN      2
#define DS1302_IO_PIN       3
#define DS1302_CE_PIN       4
#elif defined(ARDUINO_ARCH_ESP8266)
#define DS1302_CLK_PIN      D4
#define DS1302_IO_PIN       D3
#define DS1302_CE_PIN       D2
#elif defined(ARDUINO_ARCH_ESP32)
#define DS1302_CLK_PIN      0
#define DS1302_IO_PIN       4
#define DS1302_CE_PIN       5
#else
#error #error "May work, but not tested on this target"
#endif
// Create DS1302 RTC object
DS1302 rtc = DS1302(DS1302_CLK_PIN, DS1302_IO_PIN, DS1302_CE_PIN);
analyzing this and this
This guy uses the following pins for the ESP32 wroom
DS1302RTC RTC(14, 13, 16); // CLK, IO, CE
So, I check the pinout of the esp32 wroom
And I compare it with esp32 ai thinker
Sketch:
#include <DS1302.h>
DS1302 rtc(16,12,14); // rst, dat, clk
void setup() {
  Serial.begin(115200);
void loop() {
   Serial.println(rtc.getTimeStr());
    Serial.println(rtc.getDateStr());
     delay(1000);
Why do I get this on serial monitor?
Guru Meditation Error: Core00,len:6352
entry 0x400806b8
f001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Guru Meditation Error: Core  1 panic'ed (LoadStoreError). Exception was unhandled.
Core 1 register dump:
PC      : 0x400d0f38  PS      : 0x00060330  A0      : 0x800d0d21  A1      : 0x3ffb1f50
A2      : 0x3f400f05  A3      : 0x00000002  A4      : 0x00000009  A5      : 0x00000003
A6      : 0x00000001  A7      : 0x00000000  A8      : 0x00000032  A9      : 0x0000001b
A10     : 0x3ffb1f5c  A11     : 0x3ffb1f6e  A12     : 0x00000009  A13     : 0x3ffb1f64
A14     : 0x000000ff  A15     : 0x0875eb55  SAR     : 0x00000010  EXCCAUSE: 0x00000003
EXCVADDR: 0x3f400f05  LBEG    : 0x4000c349  LEND    : 0x4000c36b  LCOUNT  : 0xffffffff
Backtrace: 0x400d0f38:0x3ffb1f50 0x400d0d1e:0x3ffb1f90 0x400d1b35:0x3ffb1fb0 0x4008a53d:0x3ffb1fd0
Rebooting...
ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
ho 0 tail 12 room 4
entry 0x400806b8
Rebooting...
ets Jun  8 2016 00:22:57/code]
Chuma87
Postby Chuma87 » Wed Feb 05, 2020 2:43 pm
Extra fact:
I use the GPIO_13 pin (wake up) to receive a frequency sent to me by the CDM324 sensor, then analyze it, and after that, take a photo and save it in the SD, which also uses GPIO_13. All this works.
But when using the DS1302, it does not work, and the 5 pins are connected, including VCC & GND (DS1302) to POUT 3.3 / 5v & GND (ESP32-cam)
fede2k
Postby fede2k » Wed Apr 22, 2020 12:54 pm
have you succeed using ds3231 clock with esp32cam?
Agree007
Postby Agree007 » Wed Apr 22, 2020 4:01 pm
Depending in your code, you can implement OTA, the use gpio 1 and 3 😉
sionut
Postby sionut » Fri Nov 27, 2020 8:12 pm
Extra fact:
Did you have any success with DS1302 ? I bought a couple of DS3231 then I realized that I cannot use them with ESP32-CAM (or at least I don't think so).
Looking for another RTC to work with ESP32CAM I found your post. Could you share your results, please ?
Thank you in advance !
agussupriadi
Postby agussupriadi » Sun Dec 13, 2020 7:59 pm
hello, i really hope someone could help me with these too. it is difficult for me to find the way to connect esp32 cam with RTC..
alanesq
Postby alanesq » Mon Dec 14, 2020 7:50 am
If you use the sd card in 1-bit mode this frees up pins 4, 12 and 13
SD card access will be slower as it is only using one of the 4 data pins.
i.e. in Arduino IDE the command is: SD_MMC.begin("/sdcard", true)
You need to define them is input or output after initialising the sd card
I have then been able to connect a MCP23017 to pins 12 and 13 giving 16 gpio pins to play with, although this may not help in this case it shows you can use i2c with them.
If you don't need the flash you could desolder the LED from pin 4?
BTW - I have been experimenting recently with what I can do with these esp32cam modules and included it all in a "demo sketch": https://github.com/alanesq/esp32cam-demo
Any info/advice/suggestions would be very welcome. e.g. I would like to find a way to switch camera modes without having to de-init the camera as this is very slow (i.e. switch from greyscale to JPG mode).
Users browsing this forum: No registered users and 48 guests
