Heltec Wifi LoRa esp32 V3 don´t upload.
camilo-17
Postby camilo-17 » Mon Mar 16, 2020 5:10 pm
Hello everyone, I´m new and I never have publish a topic in this forum so excuse me if this isn´t the right place to put my problem.
I´m using the IDE for programming my heltec wifi LoRa esp32 had been working correctly but this morning I can´t upload any Sketch.
I tried to upload Blink but don't works. I have this error.
esptool.py v2.6
Serial port COM5
File "esptool.py", line 2959, in <module>
File "esptool.py", line 2952, in _main
File "esptool.py", line 2652, in main
File "esptool.py", line 222, in __init__
File "site-packages\serial\__init__.py", line 88, in serial_for_url
File "site-packages\serial\serialwin32.py", line 62, in open
serial.serialutil.SerialException: could not open port 'COM5': WindowsError(121, 'Se agot\xf3 el tiempo de espera del sem\xe1foro.')
Failed to execute script esptool
el puerto seleccionado Failed to execute script esptool
no existe o tu placa no esta conectada
My blink
void setup() {
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
void loop() {
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
The Heltec wifi lora esp32 still working with the last upload sketch.
I´m using the same cable to connect the PC and Heltec esp32. Also I don't have connect some else in the board.
And I my PC detect the COM5 as the 'silicon labs CP210x controller' of my board.
I would appreciate you help and excuse my english.
Users browsing this forum: Bing [Bot] and 90 guests
