Error message when trying to upload any sketch to my ESP32
chbck5050
Postby chbck5050 » Thu Mar 05, 2020 7:09 pm
Using the Arduino IDE, I'm trying to upload a sketch to my ESP32. One of them, for example, is the Pacifica sketch found in the examples for the FastLED library. Although this worked previously, suddenly I'm getting the following errors when I try to do it now
A fatal error occurred: Failed to set baud rate 115200. The driver may not support this rate.
At this point, my connection to my ESP32 is dropped and I have to uplug it and plug it back into the usb port. Also, this happens no matter what baud rate I set in the Arduino IDE.
This was all working fine until it simply stopped working and I'm completely at a loss as to why. My ESP32 is basically worthless right now and I'd greatly appreciate any help you guys can provide.
thefatmoop
Re: Error message when trying to upload any sketch to my ESP32
Postby thefatmoop » Thu Mar 05, 2020 7:36 pm
in device manager uninstall the com port driver, unplug it, replug it back in. If that doesn't work try a reboot after un-installing the driver.
Users browsing this forum: No registered users and 77 guests
