ESP32-CAM does not boot with DS18B20 on GPIO14
muller59
Postby muller59 » Sun Feb 02, 2020 2:58 pm
i want to use the ESP32-CAM from AI_thinker to monitor my 3D printer enclosure.
I also want to know the temperature within the enclosure.
When i enhance the standard example CameraWebServer with code to read the DS18B20 temp sensor, this compiles without error.
However, the ESP32-CAM does not boot with gpio14 connected to the DS18B20. the gpio14 is pulled up with a 4K7 resistor (ds18b20 requirement).
when i disconnect gpio14, the ESP32-CAM boots
then i connect gpio14, and the ESP32-CAM starts reading the sensor, so the code works.
i am not using any card in the ESP32-CAM
does anyone have an idea why the ESP32-CAM will not boot with gpio14 connected.
Is gpio14 the right io to use? It seems free on the AI_thinker board.
thanks for reading,
Rob
username
Re: ESP32-CAM does not boot with DS18B20 on GPIO14
Postby username » Sun Feb 02, 2020 7:05 pm
Are you using the SD card with your application ?
IO14 is the HS2_CLK signal for the SD Card socket.
muller59
Postby muller59 » Mon Feb 03, 2020 11:58 am
No, i am not using the SD card.
i am just curious which gpio port is free to use on the ESP32-CAM, all ports that are accessible via header seem to be spoken for.
Thanks for the reaction.
bobtidey
Postby bobtidey » Tue Feb 04, 2020 11:55 am
I don't know why GPIO14 would affect the boot unless it is something to do with the camera software. Maybe try it with a minimal sketch to see if that boots OK with GPIO14 pulled up.
On my camera app I do use the SD card so there is little IO free. I use RXD as GPIO3 pin; just use pinMode in setup.. This doesn't stop serial debug if required. I am sure you could use this for your temp sensor.
Chuma87
Postby Chuma87 » Tue Feb 04, 2020 2:35 pm
Hi, try using GPIO_13
I have a doppler sensor and it works great
Users browsing this forum: No registered users and 54 guests
