Hi all, is it possible to communicate with this [url]https://www.espros.com/downloads/02_Cam ... KJUwiw[url] sensor ?
it say TTL UART interface at 10 Mbit/s
I'm in arduino environment...
tnks a lot
TOF CAM sensor
Re: TOF CAM sensor
I suspect it will be difficult to make it work reliably. The ESP32 can toggle pins at 80MHz. So, a 10Mhz serial interface should be well within the limits of the hardware in terms of input and output speed at the pins. However, the general rule of thumb I've heard about serial ports on the ESP32 is that you can't expect to go over about 2-3MBits per second without hardware flow control. And, wouldn't you know, that camera does not use hardware flow control. So, I think you'll miss bytes when trying to receive at 10MBits. But, the only way to know is to try. It might be OK so long as you don't have anything else active at the time - no Wifi, no bluetooth, just serial reception.
Re: TOF CAM sensor
tnks for answering !!!
How can I set up serial comunication so fast?
Serial.begin(????????);
Re: TOF CAM sensor
something like that?
#define RXD2 16
#define TXD2 17
void setup() {
Serial.begin(115200);
Serial2.begin(10000000, SERIAL_8N1, RXD2, TXD2);
Serial.println("Serial Txd is on pin: " + String(TX));
Serial.println("Serial Rxd is on pin: " + String(RX));
void loop() {
while (Serial2.available()) {
Serial.print(char(Serial2.read()));
Users browsing this forum: christophe de poly and 26 guests
