ESP32 Deep sleep power consumption
epicac
Postby epicac » Tue Sep 17, 2019 5:23 pm
Hi guys,
recently I bought a couple of ESP32 Dev boards:
The upper one has already power indication diod soldered off. But for some reason in deep sleep the power consumption is 9.7mA (resp. 11.2mA with the diod on).
I wanted to use a 3.7V 700mAh LiPo battery but it's drained in 3 days. Battery is connected using VIN, GND pins. The test code is just this:
  1. #define uS_TO_S_FACTOR 1000000
  2. #define TIME_TO_SLEEP  30
  3.
  4. void setup() {
  5.   esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
  6.   esp_deep_sleep_start();
  7.
  8. }
  9.
  10. void loop() {
  11. }
Do you guys have any idea?
Re: ESP32 Deep sleep power consumption
Postby ESP_Sprite » Wed Sep 18, 2019 3:14 am
If any, replace the AMS1117 LDO, they're notoriously inefficient.
epicac
Postby epicac » Wed Sep 18, 2019 2:02 pm
Thanks for the answer. I have a couple of HT7333s at home, so I'll try that!
Postby ESP_Sprite » Thu Sep 19, 2019 3:57 am
You can try, but do note that those LDOs are limited to 250mA. The ESP32 needs a minimum of 500mA on WiFi initialization, otherwise it'll brown out. (If you want to test it anyway: a hacky solution would be to put two HT7333 chips in parallel.)
DavidL
Postby DavidL » Tue Oct 01, 2019 12:56 pm
Hello
I take advantage of this topic, to know LDO recommendation. for full use. ?
Users browsing this forum: No registered users and 51 guests
