ESP32-EVB Arduino; Hall sensor not working
JSP007
Postby JSP007 » Sat Aug 10, 2019 7:30 pm
I cannot make the Hall sensor example work, the plotter just shows noise and the sensor does not react when I approach the magnet.
The example is as simple as can be. I am using Arduino with the ESP32 extension.
I can get the ESP32-EVB to work with LEDs etc. so I have a serial connection that works.
The manual states that the Hall sensor stores its value in a register and hallRead() fetches it there, all done internally. The sketch does not show any specific pin either.
So, what have I missed? Should I include some file? IS there a special extension for the ESP32-EVB?
Such a simple sketch!!! I am going inte desperation level.
Please advise. Thank you very much in advance.
swargir
Re: ESP32-EVB Arduino; Hall sensor not working
Postby swargir » Thu Aug 29, 2019 10:29 am
Hello.
Enter the code here
lbernstone
Postby lbernstone » Thu Aug 29, 2019 5:25 pm
The hall sensor peripheral is inside the chip. Put the magnet right on the chip to see it react. If you have a hall sensor device, it will just be a regular input, either using ADC, SPI, or I2C (check the datasheet). Some modules/boards use pins 36 & 39, which will prevent you from using the internal hall sensor.
Users browsing this forum: No registered users and 44 guests
