How to use Callbacks in classes
Reinosoft
Postby Reinosoft » Mon Aug 12, 2019 8:36 pm
Yesterday i created with a lot of struggle an example on how to use callbacks in my librarys.
(I think i still don't understand what's really going on...)
I tested the code with an Arduino and a STM and everything works fine.
No i'm trying to convert it to the ESP32 but i can't get it to work.
I'm trying for several hours now, watched a few library examples but I don't understand how the callbacks work exactly in the ESP.
Can anyone help me with a simple example or explanation?
 extern "C" {
typedef int (*callbackFunctionArgument) (const int arg1, const int arg2);
typedef void (*callbackFunction)(void);
class testcallback {
public:
void voidCallback(callbackFunction newFunction()) {
Serial.println("VOIDCALLBACK::INIT!");
_voidCallback = newFunction;
void RunvoidCallBack() {
_voidCallback();
int FunctionArgument1(callbackFunctionArgument newFunction(int arg1, int arg2)) {
Serial.println("FUNCTIONARGUMENT1::INIT!");
_FunctionArgument1 = newFunction;
void RunCallbackArg1(int value1, int value2) {
Serial.println("Return value from local function 1:" + String(_FunctionArgument1(value1,value2)));
int FunctionArgument2(callbackFunctionArgument newFunction(int arg1, int arg2)) {
Serial.println("FUNCTIONARGUMENT2::INIT!");
_FunctionArgument2 = newFunction;
void RunCallbackArg2(int value1, int value2) {
Serial.println("Return value from local function 2:" + String(_FunctionArgument2(value1,value2)));
private:
callbackFunction _voidCallback;
callbackFunctionArgument _FunctionArgument1;
callbackFunctionArgument _FunctionArgument2;
testcallback d;
void setup() {
Serial.begin(9600);
d.voidCallback(CallbackVOID);
d.FunctionArgument1(CallbackINT1); //pass the callback to local functions
d.FunctionArgument2(CallbackINT2); //pass the callback to local function
d.RunvoidCallBack();
delay(2000);
d.RunCallbackArg1(8,16);
delay(2000);
d.RunCallbackArg2(1,2);
void CallbackVOID() {
Serial.println("\nCallbackVOID entered!");
int CallbackINT1(int a, int b) {
Serial.println("\nCallbackINT1: a=" + String(a) + "/b=" + String(b));
return 32000;
int CallbackINT2(int a, int b ) {
Serial.println("\nCallbackINT2: a=" + String(a) + "/b=" + String(b));
return 16;
void loop() {
chegewara
Re: How to use Callbacks in classes
Postby chegewara » Wed Aug 14, 2019 9:08 pm
When you create function where you pass typedef-ined callback function then you do it without arguments, because typedef already know how many and what kind arguments has this function.
public:
    void voidCallback(callbackFunction newFunction) {
      _voidCallback();
    int FunctionArgument1(callbackFunctionArgument newFunction) {
    int FunctionArgument2(callbackFunctionArgument newFunction) {
private:
testcallback d;
void setup() {
    Serial.begin(115200);
    delay(2000);
    delay(2000);
    return 32000;
    return 16;
void loop() {
Reinosoft
Postby Reinosoft » Thu Aug 15, 2019 9:34 am
Thank you very much for your help!
Regards,
Reinald
Users browsing this forum: No registered users and 74 guests
