In my project, I'm using BT SPP to communicate between ESP32 and an Android device. I'm using the Arduino IDE and currently works fine. When the ESP32 comes up, I connect the Android device to the already paired ESP32 over BT. I use a Bluetooth Serial Terminal app on the Android. Data is sent and received on both devices - no issues.
Code that we're using effectively is this:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
BluetoothSerial SerialBT;
void setup() {
Serial.begin(115200);
SerialBT.begin("ESP32test"); //Bluetooth device name
Serial.println("The device started, now you can pair it with bluetooth!");
void loop() {
if (Serial.available()) {
SerialBT.write(Serial.read());
if (SerialBT.available()) {
Serial.write(SerialBT.read());
delay(20);
What I'm looking for is:
1. How could I possibly setup the ESP32 as "client" and Android as "server". Once paired, the Android device will be in hidden/invisible/non-discoverable mode to new devices. Only the paired ESP32 "client" will be able to connect to the ANdroid device when it restarts.
2. Any "PIN" that I could set up on the ESP32 to provide some level of security?
3. Any other means by which I could make the design "intrusion" proof?
We've built quite a good system with our project using ESP32 and it has been performing very well, but this last bit is troubling us. Any help would be truly appreciated.
Regards,
Deepak
