parse http data from website
mega128
Postby mega128 » Thu Jan 24, 2019 7:33 pm
I am following an example from here:
https://techtutorialsx.com/2017/05/19/e ... -requests/
and trying to parse temperature value from a website such as https://www.wunderground.com.
I understand I should be using API for this project but I am looking to make it work using regular html payload.
Basically, I am trying to extract '43' temperature which is listed after Temperature table cell.
It's not JSON so I am looking for a way to search the payload residing in int httpCode = http.GET(); and only get temperature value.
<tr><td>Temperature</td>
  <td>
  <span class="nowrap"><b>43</b>&deg;F</span>
 </td>
  </tr>[Codebox=html5 file=Untitled.html][/Codebox]
Thanks all
Here is more of payload data
<table><tr><td> <center>
<table border="1" width="100%">
<tr><td colspan="2" ><a name="conditions"></a>
 Updated: <b>1:35 PM </b><br />Observed at
<b></b>
 </td></tr>
  <td>
 </td>
  </tr>
  <tr><td>Windchill</td>
  <td>
  <span class="nowrap"><b>34</b>&deg;F</span>
  </td></tr>
<tr><td>Humidity</td>
<td><b>93%</b></td></tr>
<tr><td>Dew Point</td>
<td>
  <span class="nowrap"><b>41</b>&deg;F</span>
</td></tr>
<tr><td>Wind</td>
<td>
<b>NW</b> at
  <span class="nowrap"><b>23</b>&nbsp;mph</span>
</td></tr>
        <tr>
                <td>Wind Gust</td>
                <td>
  <span class="nowrap"><b>30</b>&nbsp;mph</span>
</td>
        </tr>
<tr><td>Pressure</td>
<td>
  <span class="nowrap"><b>29.52</b>&nbsp;in</span>
  <b>(Falling)</b>
</td></tr>
<tr><td>Conditions</td>
<td><b>Light Rain</b></td></tr>
<tr><td>Visibility</td>
<td>
  <span class="nowrap"><b>10.0</b>&nbsp;miles</span>
</td></tr>
<tr>
        <td>UV</td>
                <td>1 out of 16</td>
</tr>
<tr><td>Clouds</td>
<td>
<b>Mostly Cloudy</b>
(BKN)
  <span class="nowrap"><b>1600</b>&nbsp;ft</span>
<br />
(BKN)
:[Codebox=html4strict file=Untitled.html][/Codebox]
mega128
Re: parse http data from website
Postby mega128 » Wed Feb 27, 2019 11:15 am
Any idea guys?
Thanks all.
Postby ESP_Sprite » Thu Feb 28, 2019 2:08 am
The complex solution to this would be to use an XML parser like expat or so to parse this, but perhaps you can get away by just searching for the string surrounding the actual temperature. I'd suggest using an API anyway, as this is an extremely brittle solution and will fail as soon as wunderground changes their layout.
GeorgeFlorian1
Postby GeorgeFlorian1 » Thu Feb 28, 2019 9:02 am
What is the API you're talking about ? Is it one that helps you parse a string from a HTML input ?
gdsports
Postby gdsports » Sat Mar 02, 2019 1:13 am
Wunderground previously supported a free HTTP API to return weather data in JSON. It was easy to use and many demos/example programs used it to create WiFi weather display stations. This service is no longer free so scraping the weather data from HTML is one option. Another option is to use openweather.com.
Users browsing this forum: No registered users and 31 guests
