hello guys
am currently working on R&D with rfid and the esp module.
i am trying to create a wireless transmission of signal from the antenna to the receiver in the sense that i want to use the esp module as a transceiver which means it is going to be connected to the antenna for reading the rfid tages after that then send the tag id to a server or any remote base network.
right now i have a DIY yagi antenna which reads the tags when connected to a tag reader, i want to use the esp as the tag reader instead so i can eliminate the use of wires and buying multiple readers at the same time.
I haven't found anything on this so far so i hope if there's anyone who can help with any sort of idea is welcome.
thanks.
regards,
Azeez
Wireless transmission of antenna signal with esp modules
Re: Wireless transmission of antenna signal with esp modules
So you want to use the Wifi antenna of the ESP to read the RFID?
I'm certainly no expert in antennas, but aren't RFID and Wifi antennas totally different, i.e. in both form and frequency?
i want a reader which will have a reader connected to esp module to read tags and then sent to server by esp module.
Users browsing this forum: No registered users and 29 guests
