hi!
Don't know if this is already answered, I can't find it anywhere, how are the pins of the ESP32-Wrover-Kit (the big board with screen) named into the Arduino?
ESP-Wrover-Kit pin names in Arduino
Re: ESP-Wrover-Kit pin names in Arduino
I'm using a different kit but simply use the pin numbers in Arduino code, for example:
pinMode(32,OUTPUT)
digitalWrite(32,LOW);
I tried that to, but some pins don't follow the logic, I don't get anything from the pins
IO16, 17, 22, 36, 34, 39, 35, 32, 33 from the big row of pins, also how the pins in the SPI interface are addressed?
This should be specified somewhere, isn't?
As documented here, pins 34 to 39 can only be set as input mode and do not have software pullup or pulldown functions. Also pins 6-11 are used for the SPI flash memory. Pin 0 (zero) is used by the 'Boot' button. Furthermore from this documentation of the Wrover: "GPIO16 and GPIO17 are used as the CS and clock signal for PSRAM. To ensure reliable performance, the two GPIOs are not broken out."
I have not tried to get SPI to work, but I understand the ESP32 Arduino IDE includes an SPI library (GitHub reference).
Pin 22 works as an output on my board (it's not a ESP-Wrover-Kit).
ok, I will need to make some rewiring now, Thanks!
hallo, I have just spent too much time trying to map out my new Adfruit feather ESP-32 and this is what i have found....
Pls ignore the base image as it is for a 8266, the blue tags are labled with the pin number that worked as an output pin for me..
Use at your own risk.. Hope this helps someone
Users browsing this forum: Google [Bot] and 66 guests
