Problem with I2C LCD 2x16
Pyshco
Postby Pyshco » Sat Apr 07, 2018 12:20 am
When i was tring to use this LCD with a I2C i get this output (sorry for the output been in spanish):
Arduino:1.8.5 (Windows 10), Tarjeta:"ESP32 Dev Module, 80MHz, 115200, None"
ATENCIÓN: la librería LiquidCrystal_I2C pretende ejecutarse sobre arquitectura(s) (avr) y puede ser incompatible con tu actual tarjeta la cual corre sobre arquitectura(s) (esp32).
Archiving built core (caching) in: C:\Users\ivann\AppData\Local\Temp\arduino_cache_221535\core\core_espressif_esp32_esp32_FlashFreq_80,UploadSpeed_115200,DebugLevel_none_036d094178c15d2544f64c911288978f.a
El Sketch usa 110074 bytes (8%) del espacio de almacenamiento de programa. El máximo es 1310720 bytes.
Las variables Globales usan 9892 bytes (3%) de la memoria dinámica, dejando 285020 bytes para las variables locales. El máximo es 294912 bytes.
esptool.py v2.0-beta3
Connecting....
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash params set to 0x022f
Compressed 11120 bytes to 7191...
A fatal error occurred: Timed out waiting for packet content
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
It is the LiquidCrystal_I2C library who is having the problem... any way to solve this or another library?
WiFive
Re: Problem with I2C LCD 2x16
Postby WiFive » Sat Apr 07, 2018 1:26 am
What pins you use for i2c?
Pyshco
Postby Pyshco » Sat Apr 07, 2018 3:34 am
Thanks for the quick reply!
The pins i'm using are: For the SDA(io12) and for the SCL(io14).
WiFive
Postby WiFive » Sat Apr 07, 2018 5:09 am
Gpio12 is a strapping pin you can't pull it high on boot with wroom32 3.3v flash
Pyshco
Postby Pyshco » Sat Apr 07, 2018 2:33 pm
Thanks for the help, now it compliles... now, i've got another issue. You see, now it compiles but doesn't show anything in the screen, i tryied ajusting the contrast but nothing... how can i fix this?
This is the code that i'm using:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);//set the LCD address to 0x27 for a 16 chars and 2 line display
void setup(){
  lcd.begin(26, 27);// initialize the lcd with SDA and SCL pins
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0,0);
  lcd.print("Something");
  lcd.setCursor(0,1);
  lcd.print("Test?");
void loop(){
WiFive
Postby WiFive » Sat Apr 07, 2018 2:46 pm
Users browsing this forum: No registered users and 32 guests
