Serial monitor output not working after starting i2c wire library
youmebangbang
Postby youmebangbang » Sun Sep 17, 2017 1:03 am
I am using the arduino IDE and want to get I2C data from a wii nunchuck controller. I am just trying to Serial.print() some values but nothing goes to the com viewer after wire is started.
void setup() {
   Serial.begin(115200);
  Serial.println("HELLO");
  Wire.begin(NUNCHUK_ADDRESS);
  Wire.beginTransmission(NUNCHUK_ADDRESS);
  Wire.write(0xF0);
  Wire.write(0x55);
  Wire.endTransmission();
  Wire.write(0xFB);
  Wire.write(0x00);
  Serial.println("end of setup");
It outputs "HELLO" but not "end of setup". Am I correct that wire and serial are default sharing something important in the esp32?
Thanks.
Re: Serial monitor output not working after starting i2c wire library
Postby ESP_Sprite » Mon Sep 18, 2017 1:33 am
Moved to the Arduino subforum.
martinayotte
Postby martinayotte » Mon Sep 18, 2017 2:51 pm
Do you have PullUps on I2C lines ?
tele_player
Postby tele_player » Tue Sep 26, 2017 3:10 am
Wire.begin() must be called without an address to initialize ESP as I2C master.
Users browsing this forum: Bing [Bot] and 120 guests
