Hi.
I have created a simple test project using the Arduino platform on VSCode for the ESP32-S3-N16R8 Board-USBC module.
After compiling and uploading the project to the board, the ESP32-S3 is unable to start properly and keeps resetting continuously.
But, I tested the same ESP32-S3 module with Arduino IDE 2.3.3, and it worked well.”
Maybe something wrong with PIO configuration and tools?
I would appreciate your advice on how to resolve this issue.
Below is the serial output:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x8 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x4bc
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a0c
entry 0x403c98d0
Build:Mar 27 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403cdb0a
SPIWP:0xee
entry 0x403c98d0
Here is the main.cpp file:
#include <Arduino.h>
void setup() {
Serial.begin(115200);
delay(2000);
Serial.println(“Setup()”);
void loop() {
Serial.println(“loop”);
And the platformio.ini configuration:
[env:esp32-s3-devkitc-1-n16r8v]
platform = espressif32
board = esp32-s3-devkitc-1-n16r8v
framework = arduino
build_flags =
-DCORE_DEBUG_LEVEL=1
-Wl,-Map,output.map
Attached are the following files:
(a) sdkconfig from C:\Users\aaa.platformio\packages\framework-arduinoespressif32\tools\sdk\esp32s3
(b) esp32-s3-devkitc-1-n16r8v.json from C:\Users\ACEN.platformio\platforms\espressif32\boards
I cannot attach the files. If necessary to find the cause of the problem, I will upload the content.”
Thank you for your assistance.
Best regards,
sjkim
Issue with ESP32-S3-N16R8 Board Resetting Continuously
Re: Issue with ESP32-S3-N16R8 Board Resetting Continuously
You have not included your json file for that board, but the symptoms sound like it is not compiling with OPI memory support. Make sure your module is a esp32-s3-wroom-2, and use the following options.
[env:esp32-s3-n16r8]
platform = https://github.com/pioarduino/platform-espressif32/releases/download/51.03.05/platform-espressif32.zip
framework = arduino
board_build.arduino.memory_type = qio_opi
board_build.flash_mode = qio
board_build.prsam_type = opi
board_upload.flash_size = 16MB
board_upload.maximum_size = 16777216
board_build.extra_flags = -DBOARD_HAS_PSRAM
Users browsing this forum: dirk degrave and 25 guests
