I am using Arduino as an IDF component and I am able to run code on the Metro board. I can see the ESP_LOGx messages in the "idf.py monitor" window, but I am not seeing the Serial.print() output? Where is Serial configured. I would like the Serial.print to go to the USB out, same as ESP_LOG.
Serial.print on Adafruit ESP32S3 Metro board
Re: Serial.print on Adafruit ESP32S3 Metro board
Thanks, I see that but I am trying to build my app with the IDF tools (Arduino is installed as a component) but I cannot find the right setting. I get the expected result if I use the Arduino IDE, I get the expected results.
That link also shows the define macros you should set before you call initArduino that match the settings from the tools menu.
Ok that's easy to do. Do I define the macro before the call to initArduino, or should the #define be used to compile the whole component? When looking at HardwareSerial.h it looks like the define are needed when compiling the components.
- #if !defined(NO_GLOBAL_INSTANCES) && !defined(NO_GLOBAL_SERIAL)
- #ifndef ARDUINO_USB_CDC_ON_BOOT
- #define ARDUINO_USB_CDC_ON_BOOT 0
- #endif
- #if ARDUINO_USB_CDC_ON_BOOT //Serial used from Native_USB_CDC | HW_CDC_JTAG
- #if ARDUINO_USB_MODE // Hardware CDC mode
- // Arduino Serial is the HW JTAG CDC device
- #define Serial HWCDCSerial
- #else // !ARDUINO_USB_MODE -- Native USB Mode
- // Arduino Serial is the Native USB CDC device
- #define Serial USBSerial
- #endif // ARDUINO_USB_MODE
- #else // !ARDUINO_USB_CDC_ON_BOOT -- Serial is used from UART0
- // if not using CDC on Boot, Arduino Serial is the UART0 device
- #define Serial Serial0
- #endif // ARDUINO_USB_CDC_ON_BOOT
- // There is always Seria0 for UART0
- extern HardwareSerial Serial0;
- #if SOC_UART_NUM > 1
- extern HardwareSerial Serial1;
- #endif
- #if SOC_UART_NUM > 2
- extern HardwareSerial Serial2;
- #endif
- #endif //!defined(NO_GLOBAL_INSTANCES) && !defined(NO_GLOBAL_SERIAL)
If I define:
target_compile_options(${COMPONENT_TARGET} PUBLIC
-DARDUINO=10812
-DARDUINO_${idf_target_for_macro}_DEV
-DARDUINO_ARCH_ESP32
-DARDUINO_BOARD="${idf_target_caps}_DEV"
-DARDUINO_VARIANT="${CONFIG_ARDUINO_VARIANT}"
-DARDUINO_USB_CDC_ON_BOOT=1
-DARDUINO_USB_MODE=0
-DESP32)
Then I get compilation errors:
/HardwareSerial.h:350:16: error: 'USBSerial' was not declared in this scope; did you mean 'Serial'?
350 | #define Serial USBSerial
when compiling .../cores/esp32/chip-debug-report.cpp:290:3: note: in expansion of macro 'Serial'
-DARDUINO=10812
-DESP32)
Users browsing this forum: No registered users and 118 guests
