BluesBoyDje wrote:Thank you both for your help, it was indeed the library that had trouble with local ip adresses. I now got it working with another one
Could you please explain the method to solve the issue?
Because I've experienced the same issue.
For all esp 32 expert,
I can't browse esp32.local in my web browser.
I'm using this code for my ESP32
https://github.com/espressif/arduino-es ... Server.ino
In my arduino serial monitor only show:
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0010,len:4
load:0x3fff0014,len:588
load:0x40078000,len:0
load:0x40078000,len:10472
entry 0x40078a28
Connected to B520
IP address: 192.168.1.3
mDNS responder started
TCP server started
I'm using windows 7 and have installed bonjour with enable firewall.
Previously I have set my esp32 as server and client with no problem. When I try to set multicastDNS to autodetect my ip of esp32, the problem was occured.
Thank you,
Saaddin
