problem with wifi connection with my router
MRamone
Postby MRamone » Fri Sep 29, 2023 4:17 pm
hi,
my diy board with ESP32-C3 doesn't want to connect via wifi to my router. Whatever i try (the examples in Arduino IDE or other code i find in the internet...) i get the following:
eventCallback(): Reason: 2 - AUTH_EXPIRE
however, it does connect to my smartphone hotspot without any issues and works fine.
Other commercial ESP32-C3 boards and WROVER boards i have don't show this problem.
I have seen many people reporting similar issues, but have not found a reason nor a solution.
Any ideas? thanks!
lbernstone
Re: problem with wifi connection with my router
Postby lbernstone » Fri Sep 29, 2023 6:36 pm
Enable "Erase All Flash Before Sketch Upload" and see if there is an invalid lease stuck in your flash.
Turn on verbose debugging and post the whole transaction.
What is the brand/model of the router?
MRamone
Postby MRamone » Sat Sep 30, 2023 2:44 pm
thanks for your answer.
Did as you said, this is what comes out (in a loop) when running the SimpleWIFIServer:
[ 42597][W][WiFiGeneric.cpp:1057] _eventCallback(): Reason: 2 - AUTH_EXPIRE
[ 42604][D][WiFiGeneric.cpp:1081] _eventCallback(): WiFi AutoReconnect Running
[ 42620][V][WiFiGeneric.cpp:97] set_esp_interface_ip(): Configuring Station static IP: 0.0.0.0, MASK: 0.0.0.0, GW: 0.0.0.0
...[ 44282][V][WiFiGeneric.cpp:362] _arduino_event_cb(): STA Disconnected: SSID: Luxembourg Online CPM, BSSID: xx:xx:xx:xx:xx:xx, Reason: 2
[ 44283][D][WiFiGeneric.cpp:1035] _eventCallback(): Arduino Event: 5 - STA_DISCONNECTED
[ 44290][W][WiFiGeneric.cpp:1057] _eventCallback(): Reason: 2 - AUTH_EXPIRE
MRamone
Postby MRamone » Sat Sep 30, 2023 2:47 pm
my router is a fritzbox 5490
lbernstone
Postby lbernstone » Sat Sep 30, 2023 6:12 pm
Fritzbox routers have always been an issue for esp32. Try putting WiFi.disconnect(false,true); before you call WiFi.begin
MRamone
Postby MRamone » Sat Sep 30, 2023 7:09 pm
no luck i am afraid :-/
lbernstone
Postby lbernstone » Sat Sep 30, 2023 7:44 pm
I don't have one, so I can only point you to discussion about it.
https://github.com/espressif/arduino-esp32/issues/2501
MRamone
Postby MRamone » Sat Sep 30, 2023 8:21 pm
thanks, i appreciate your help!
Users browsing this forum: No registered users and 102 guests
