S3 BootLoop Revisited
michalk
Postby michalk » Thu Dec 22, 2022 8:40 pm
ESP32-S3-DevKitC-1
I am working on a small web server project with OTA update capability. I'm trying to use the official packages, and am not sure if I'm not doing something right, or perhaps the S3 isn't supported like I think it should be.
My platformio.ini file:
[env:esp32-s3-devkitc-1]
platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.2.3/platform-espressif32-2.0.2.3.zip	; wifi works, but OTA updates don't
; platform = https://github.com/tasmota/platform-espressif32/releases/download/v2.0.3rc1/platform-espressif32-2.0.3new.zip	; wifi doesn't work
; platform = https://github.com/tasmota/platform-espressif32/releases/download/2022.12.0/platform-espressif32.zip			; wifi fails
; platform = espressif32
; platform = https://github.com/platformio/platform-espressif32.git	; boot loop
; platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32#master
board = esp32-s3-devkitc-1
framework = arduino
monitor_filters = esp32_exception_decoder
monitor_speed = 115200
My code:
#include <Arduino.h>
// #include <WiFi.h>
const char* ssid = "ssid";
const char* password = "password";
void setup(void) {
  Serial.begin(115200);
  // WiFi.mode(WIFI_STA);
  // WiFi.begin(ssid, password);
  Serial.println("Compiled at " + String(__TIME__) + " " + String(__DATE__));
  // uint32_t wifiTimeout = 30000;
  // while (WiFi.status() != WL_CONNECTED) {
  //   delay(500);
  //   Serial.println(WiFi.status());
  //   Serial.println(String((int)((millis()/(float)wifiTimeout)*100)) + "% ");
void loop(void) { }
When I use the tasmota platform (see comments above for various versions):
  • no bootloop
  • wifi works
  • OTA updates don't work
When I use the stock "espressif32":
  • no bootloop
  • wifi.status() returns 255
When I use the platformio platform:
  • bootloop
Is the S3 not yet working (in general) for Platformio?
username
Re: S3 BootLoop Revisited
Postby username » Thu Dec 22, 2022 9:02 pm
I have had the same issue for about a month. My get arround was to add
platform = espressif32@5.1.0
in platform.ini file.
When I use the default "platform = espressif32" it just keeps rebooting. I have been to busy to check platformIO's site as to why this is.
michalk
Postby michalk » Thu Dec 22, 2022 9:18 pm
Hmm, this is frustrating. I just pinned it to the 5.1.0 version and it still bootloops.
username
Postby username » Thu Dec 22, 2022 9:32 pm
Sorry it didn't work for you. Hopefully someone else can chime in.
michalk
Postby michalk » Fri Dec 23, 2022 4:00 pm
After much digging, I should know better. Something similar has bitten me before.
ESP32-S3-WROOM-2-D3N32R8V
ESP32-S3-WROOM-2-M0N32R8V
The WROOM-2 still have problems with a few things. The biggest is flashing the image, so while I could flash an image via UART, I could not do it via OTA. Additionally, WiFi would work, but only on select Tasmota versions.
I am testing now with the ESP32-S3-WROOM-1-D2N8R8, and everything works as expected.
Note to self: Don't get greedy buying the latest greatest.
Eventually, all of the features will get ironed out on the 32MB S3.
chegewara
Postby chegewara » Fri Dec 23, 2022 9:35 pm
It would be good if you post the logs.
If its arduino build version then most likely logs wont be very helpful, but who knows.
Is it possible that you are building firmware for DIO/QIO version and the module is OPI version?
Its something new and we (users) have to learn it hard way, but modules with OPI flash has issues with QIO/DIO firmware vice versa (im just not sure if its firmware or just bootloader problem).
Users browsing this forum: No registered users and 37 guests
