Flash issue ESP32-PICO-MINI-02
reza_neam
Postby reza_neam » Fri Sep 16, 2022 8:24 pm
I recently switched from TTGO-Micro32-v2 to ESP32-PICO-MINI-02
But I can't make it work and can't troubleshoot the source of the issue!
When I connect the MCU to PC (USB-bridge) in terminal MCU endlessly prints this
invalid header: 0xffffffff
After burning a very simple code (I use PlatformIO), I get slighly different error as follows
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 271414342, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:1184
load:0x40078000,len:12812
load:0x40080400,len:3032
entry 0x400805e4
When I try to erase the flash, it seems everything is working just fine!
Connecting...................
Chip is ESP32-PICO-V3-02 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, Embedded Flash, Embedded PSRAM, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:83:98:d0:1c:b0
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 5.1s
Hard resetting via RTS pin...
Could you please help me to find out what would be wrong?
Users browsing this forum: No registered users and 80 guests
