Reducing touch sensor sensitivity
daxliniere
Postby daxliniere » Wed Jul 20, 2022 3:33 pm
I'm working on a project and it has a touch sensor using an ESP32 pin. The prototype worked really well, but now that it's installed in its aluminium casing, the touch threshold has dropped from <15 to <5. This is causing intermittant triggering even when the unit is not being touched. The pin is electrically connected to the casing.
Is there a way to reduce the sensitivity of the touch sensor? Either by software or hardware?
This is the test code I'm using:
#include <esp_adc_cal.h>
const int touchSensor = 32; //pin number
const int touchThresh = 5; //was 15
void setup()
  Serial.begin(115200);
void loop()
  Serial.print("Touch: ");
  if (touchRead(touchSensor) < touchThresh) {
    Serial.print("yes");
  else {
    Serial.print("no");
  Serial.print("    touch value: ");
  Serial.println(touchRead(touchSensor));
  delay(100);
Any help would be greatly appreciated.
All the best,
Dax.
Users browsing this forum: Baidu [Spider] and 34 guests
