Calculating RSSI value while using ESP_NOW protocol
cipher
Postby cipher » Sat Aug 24, 2024 6:38 pm
Hi, I have been using ESP_NOW protocol to create a many to one network with my ESP32 wroom, I want to check the RSSI value of to calculate the distance between 2 ESP32.
Below is the Reciever code, but it Outputs a constant value of -93.
#include <stdio.h>
#include <string.h>
#include <esp_log.h>
#include <esp_err.h>
#include <esp_wifi.h>
#include <esp_now.h>
#include <nvs_flash.h>
static const char *TAG = "esp_now_receiver";
// Structure example to receive data
typedef struct struct_message {
    char a[32];
    int b;
    float c;
    bool d;
} struct_message;
// Create a struct_message called myData
struct_message myData;
// Callback function that will be executed when data is received
void OnDataRecv(const uint8_t *mac_addr, const uint8_t *incomingData, int len) {
    memcpy(&myData, incomingData, sizeof(myData));
    // Get the RSSI value
    wifi_pkt_rx_ctrl_t *pkt_ctrl = (wifi_pkt_rx_ctrl_t *)(incomingData - sizeof(wifi_pkt_rx_ctrl_t));
    int8_t rssi = pkt_ctrl->rssi;
    ESP_LOGI(TAG, "Bytes received: %d", len);
    ESP_LOGI(TAG, "Char: %s", myData.a);
    ESP_LOGI(TAG, "Int: %d", myData.b);
    ESP_LOGI(TAG, "Float: %f", myData.c);
    ESP_LOGI(TAG, "Bool: %s", myData.d ? "true" : "false");
    ESP_LOGI(TAG, "RSSI: %d dBm", rssi);
void app_main(void) {
    esp_err_t ret;
    // Initialize NVS
    ret = nvs_flash_init();
    ESP_ERROR_CHECK(ret);
    // Initialize Wi-Fi
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
    ESP_ERROR_CHECK(esp_wifi_start());
    // Initialize ESP-NOW
    ESP_ERROR_CHECK(esp_now_init());
    // Register receive callback function
    ESP_ERROR_CHECK(esp_now_register_recv_cb(OnDataRecv));
    // Enter an infinite loop
    while (1) {
        vTaskDelay(pdMS_TO_TICKS(1000)); // Delay to allow background tasks to run
I would be grateful if anyone can help me with this problem.
Users browsing this forum: Bing [Bot] and 21 guests
