ESP32-S3 Camera Example
Hi, ESP32-S3 has a dedicated camera peripheral which uses DVP interface. I am not able to find any example of using this peripheral in the SDK examples. Can someone explain where it could be or if it is even available.
Re: ESP32-S3 Camera Example
You probably want https://github.com/espressif/esp32-camera .
Oh, it was so informative! Thank you for redirecting to another non-informative page. I searching for days on how phisically to connect my camera, and see only answers like thisESP_Sprite wrote: ↑Wed Jun 01, 2022 8:15 amYou probably want https://github.com/espressif/esp32-camera .
You are responding to a topic where someone asks for a software example, and you're angry the answer is a software example rather than how to physically connect the camera? I'm confused. If you need help connecting your camera, why not start a topic asking for exactly that?antonpegov wrote: ↑Thu Feb 01, 2024 7:46 am
Despite that topic starter asked for software example and got his answer - the connection defined in Initialisation section https://github.com/espressif/esp32-came ... ializationantonpegov wrote: ↑Thu Feb 01, 2024 7:46 amOh, it was so informative! Thank you for redirecting to another non-informative page. I searching for days on how phisically to connect my camera, and see only answers like thisESP_Sprite wrote: ↑Wed Jun 01, 2022 8:15 amYou probably want https://github.com/espressif/esp32-camera .
Camera interface has 8 bit parallel bus defined there as D0-D7, sync signal, parallel clock signal, href and some kind of i2c interface for camera control (XCLK, SIOD, SIOC) all mentioned in this code example in super informative way with GPIO pins of ESP32, the "-1" means not connected. Some cameras has 10bit bus etc, but can work in 8 bit as popular ov2640.
#include "esp_camera.h"
//WROVER-KIT PIN Map
#define CAM_PIN_PWDN -1 //power down is not used
#define CAM_PIN_RESET -1 //software reset will be performed
#define CAM_PIN_XCLK 21
#define CAM_PIN_SIOD 26
#define CAM_PIN_SIOC 27
#define CAM_PIN_D7 35
#define CAM_PIN_D6 34
#define CAM_PIN_D5 39
#define CAM_PIN_D4 36
#define CAM_PIN_D3 19
#define CAM_PIN_D2 18
#define CAM_PIN_D1 5
#define CAM_PIN_D0 4
#define CAM_PIN_VSYNC 25
#define CAM_PIN_HREF 23
#define CAM_PIN_PCLK 22
static camera_config_t camera_config = {
.pin_pwdn = CAM_PIN_PWDN,
.pin_reset = CAM_PIN_RESET,
.pin_xclk = CAM_PIN_XCLK,
.pin_sccb_sda = CAM_PIN_SIOD,
.pin_sccb_scl = CAM_PIN_SIOC,
.pin_d7 = CAM_PIN_D7,
.pin_d6 = CAM_PIN_D6,
.pin_d5 = CAM_PIN_D5,
.pin_d4 = CAM_PIN_D4,
.pin_d3 = CAM_PIN_D3,
.pin_d2 = CAM_PIN_D2,
.pin_d1 = CAM_PIN_D1,
.pin_d0 = CAM_PIN_D0,
.pin_vsync = CAM_PIN_VSYNC,
.pin_href = CAM_PIN_HREF,
.pin_pclk = CAM_PIN_PCLK,
I adapted the timelapse code from ESP32-CAM to also work with ESP32-S3-Wroom1 CAM (with PSRAM enabled)
I also identified the SD card pins for timelapse snapshots to be written to SD card.
You can try my code below, only tested with the ESP32-S3 WROOM N16R8 from ali*, not sure for other variants.
https://github.com/mihvoi/ESP32S3CamTimeLapse
Users browsing this forum: No registered users and 12 guests
