ESP32C2 RYLR993 LoRaWAN Communication
WardMas
Postby WardMas » Fri Jun 09, 2023 8:37 pm
https://youtu.be/zhOi7GMKKLE
In this tutorial, I have built a simple system that is powered with 1 W 5 V solar panel that monitors the connected battery voltage with ADC and gets the environment temperature and shares this information with the thing network over LoRaWAN. The system also supports modifying GPIO state wirelessly over LoRaWAN.
The system uses RYLR993 LoRaWAN Module and ESP32C2 as hosting MCU. The LoRaWAN module is controlled using AT commands over UART and contains an internal temperature sensor that the system makes use of.
All project materials are shared on my GitHub repository.
https://github.com/UsefulElectronics/es ... ge-lorawan
circuit diagram.PNG (990.77 KiB) Viewed 6327 times
Battery charging circuit.PNG (882.59 KiB) Viewed 6327 times
You can always visit my YouTube channel for embedded systems related tutorials
https://youtube.com/user/wardzx1
Users browsing this forum: No registered users and 30 guests
