HC-SR04 using RMT - very fast
Re: HC-SR04 using RMT - very fast
Postby ESP_Sprite » Thu Jun 20, 2019 5:05 am
It possibly needs
 rmt_config_t rmt_rx;
changed into
 rmt_config_t rmt_rx={0};
uberthoth
Postby uberthoth » Sat Jun 22, 2019 4:14 pm
I tried making the suggested change, which didn't seem to work, so I also changed `rmt_tx` as well. And I also tried changing the double to a float (as I hear there are issues with double math on the esp32), and changed out the 1000 * 1000 * 2 [which I know should taken care of by the compiler but it's still not working so I'll try anything]). I still get an error on this line:
distance = 340.29 * ITEM_DURATION(item->duration0) / (  2000000 ); // distance in meters
here is the changed code:
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "freertos/semphr.h"
#include "esp_err.h"
#include "esp_log.h"
#include "driver/rmt.h"
#include "driver/periph_ctrl.h"
#include "soc/rmt_reg.h"
#include <sys/time.h>
#include "driver/gpio.h"
#define RMT_TX_CHANNEL 1 /* RMT channel for transmitter */
#define RMT_TX_GPIO_NUM PIN_TRIGGER /* GPIO number for transmitter signal */
#define RMT_RX_CHANNEL 0 /* RMT channel for receiver */
#define RMT_RX_GPIO_NUM PIN_ECHO /* GPIO number for receiver */
#define RMT_CLK_DIV 100 /* RMT counter clock divider */
#define RMT_TX_CARRIER_EN 0 /* Disable carrier */
#define rmt_item32_tIMEOUT_US 9500 /*!< RMT receiver timeout value(us) */
#define RMT_TICK_10_US (80000000/RMT_CLK_DIV/100000) /* RMT counter value for 10 us.(Source clock is APB clock) */
#define ITEM_DURATION(d) ((d & 0x7fff)*10/RMT_TICK_10_US)
#define PIN_TRIGGER 18
#define PIN_ECHO 19
static void HCSR04_tx_init()
rmt_config_t rmt_tx={0};
rmt_tx.channel = RMT_TX_CHANNEL;
rmt_tx.gpio_num = RMT_TX_GPIO_NUM;
rmt_tx.mem_block_num = 1;
rmt_tx.clk_div = RMT_CLK_DIV;
rmt_tx.tx_config.loop_en = false;
rmt_tx.tx_config.carrier_duty_percent = 50;
rmt_tx.tx_config.carrier_freq_hz = 3000;
rmt_tx.tx_config.carrier_level = 1;
rmt_tx.tx_config.carrier_en = RMT_TX_CARRIER_EN;
rmt_tx.tx_config.idle_level = 0;
rmt_tx.tx_config.idle_output_en = true;
rmt_tx.rmt_mode = 0;
rmt_config(&rmt_tx);
rmt_driver_install(rmt_tx.channel, 0, 0);
static void HCSR04_rx_init()
rmt_rx.channel = RMT_RX_CHANNEL;
rmt_rx.gpio_num = RMT_RX_GPIO_NUM;
rmt_rx.clk_div = RMT_CLK_DIV;
rmt_rx.mem_block_num = 1;
rmt_rx.rmt_mode = RMT_MODE_RX;
rmt_rx.rx_config.filter_en = true;
rmt_rx.rx_config.filter_ticks_thresh = 100;
rmt_rx.rx_config.idle_threshold = rmt_item32_tIMEOUT_US / 10 * (RMT_TICK_10_US);
rmt_config(&rmt_rx);
rmt_driver_install(rmt_rx.channel, 1000, 0);
void app_main()
HCSR04_tx_init();
HCSR04_rx_init();
rmt_item32_t item;
item.level0 = 1;
item.duration0 = RMT_TICK_10_US;
item.level1 = 0;
item.duration1 = RMT_TICK_10_US; // for one pulse this doesn't matter
size_t rx_size = 0;
RingbufHandle_t rb = NULL;
rmt_get_ringbuf_handle(RMT_RX_CHANNEL, &rb);
rmt_rx_start(RMT_RX_CHANNEL, 1);
//double distance = 0;
float distance = 0;
for(;;)
rmt_write_items(RMT_TX_CHANNEL, &item, 1, true);
rmt_wait_tx_done(RMT_TX_CHANNEL, portMAX_DELAY);
rmt_item32_t* item = (rmt_item32_t*)xRingbufferReceive(rb, &rx_size, 1000);
//distance = 340.29 * ITEM_DURATION(item->duration0) / (1000 * 1000 * 2); // distance in meters
printf("Distance is %f cm\n", distance * 100); // distance in centimeters
vRingbufferReturnItem(rb, (void*) item);
vTaskDelay(200 / portTICK_PERIOD_MS);
and full output:
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x400d248d  PS      : 0x00060530  A0      : 0x800d0b09  A1      : 0x3ffb4d10
0x400d248d: app_main at /home/thoth/git/A9thinker/GPRS_C_SDK/tank_gauge/sr04test/main/bstx03_XiuxinESP32.c:89 (discriminator 1)
A2      : 0x00000000  A3      : 0x00000001  A4      : 0x00000001  A5      : 0x00000001
A6      : 0x00060021  A7      : 0x00000000  A8      : 0x800d248b  A9      : 0x3ffb4cd0
A10     : 0x00000000  A11     : 0x3ffb4d14  A12     : 0x000003e8  A13     : 0x00000001
A14     : 0x00000040  A15     : 0x3ffb699c  SAR     : 0x00000020  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000  LBEG    : 0x4000c46c  LEND    : 0x4000c477  LCOUNT  : 0x00000000
ELF file SHA256: 3557e67f93dae1bed9df867b800bd1c138d6258b7677ba69e6fbc3003389d3c1
Backtrace: 0x400d248d:0x3ffb4d10 0x400d0b06:0x3ffb4d40 0x40085625:0x3ffb4d60
0x400d0b06: main_task at /home/thoth/esp/esp-idf/components/esp32/cpu_start.c:527
0x40085625: vPortTaskWrapper at /home/thoth/esp/esp-idf/components/freertos/port.c:403
Rebooting...
uberthoth
Postby uberthoth » Tue Jun 25, 2019 3:09 pm
I got this working by adding the if clause on item:
#include <stdio.h>
#include <string.h>
#define PIN_ECHO 19
static const char* NEC_TAG = "NEC";
void app_main()
HCSR04_tx_init();
HCSR04_rx_init();
rmt_item32_t item;
item.level0 = 1;
item.level1 = 0;
size_t rx_size = 0;
//float distance = 0;
for(;;)
if(item){
 // distance = 340.29 * ITEM_DURATION(item->duration0) / (  2000000 ); // distance in meters
  ESP_LOGI(NEC_TAG, "Distance is %f cm\n", distance * 100); // distance in centimeters
} else {
  ESP_LOGI(NEC_TAG, "Distance is not readable");
vTaskDelay(20 / portTICK_PERIOD_MS);
mikronauts
Postby mikronauts » Sun Jun 30, 2019 2:33 pm
The time taken to perform that calculation is less than 1/1000 the time to get the distance from the hcsr04.
Insignificant.
uberthoth
Postby uberthoth » Mon Jul 08, 2019 3:59 pm
mikronauts wrote: The time taken to perform that calculation is less than 1/1000 the time to get the distance from the hcsr04.
Insignificant.
Which calculation are you talking about?
mikronauts
Postby mikronauts » Tue Jul 09, 2019 12:29 am
I was pointing out that worrying about the impact of integer vs floating point math (single or double precision) is not worth the effort, as even the slowest method is totally insignificant compared to the meadurement interval.
Insignificant.
AlbertH
Postby AlbertH » Thu Feb 04, 2021 10:26 am
First of all, I have very little software experience, I am more a hardware designer (FPGA). I want to measure the with of a tacho pulse with the RMT registers. What I did was placing the code in my Arduino development tool and then started the compiler.
I got a lot of errors which also happens with other examples about the RMT registers.
The error I get is:
...\Arduino\sketch_feb04a\sketch_feb04a\sketch_feb04a.ino: In function 'void HCSR04_tx_init()':
sketch_feb04a:32:16: error: invalid conversion from 'int' to 'rmt_channel_t' [-fpermissive]
Can someone help to solve this problem?
Thanks in Advance
Users browsing this forum: No registered users and 16 guests
