Hello All,
I want to share a recent project of mine with you. This is a design based on ESP32 chip. It is compatible with open source esp-at project. One can easily develop a custom firmware on it as well. Schematics, layout, PCB antenna design and simulations, pin out diagram, part list and much more are available on the link below:
https://github.com/uysan/iot-esp-eth
It is an "Open Source Hardware" developed with "Open Source Software". The software list includes but not limited to KiCAD, OpenEMS and Octave.
The board has ESP32-D0WD-V3 MCU, 16 MB serial flash memory (W25Q128JVSIQ), 10/100 Mbit Ethernet (RTL8201F), 2.4GHz PCB antenna, USB-Serial programming, monitoring and general purpose interface (CH340G), 5V to 3.3V voltage regulator (1117 series), 2.93V supply voltage supervisor (APX811-29UG), protection components and RF shield.
Kind Regards,
Selçuk
Open Source ESP32 Ethernet, Wi-Fi & Serial Gateway
- 3dview.png (250.11 KiB) Viewed 4522 times
- blocks.png (125.59 KiB) Viewed 4522 times
- pinout.png (287.06 KiB) Viewed 4522 times
Re: Open Source ESP32 Ethernet, Wi-Fi & Serial Gateway
PCB layers and antenna simulation.
- layers.png (268.24 KiB) Viewed 4413 times
- ems.png (219.95 KiB) Viewed 4413 times
- smith.png (71.21 KiB) Viewed 4413 times
More images...
- uys2101ia.jpg (1.05 MiB) Viewed 4494 times
- uys2101ca.jpg (1.02 MiB) Viewed 4494 times
- production.jpg (3.15 MiB) Viewed 4494 times
Users browsing this forum: No registered users and 7 guests
