Is this a bug Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
adrianmolecule
Postby adrianmolecule » Wed Apr 13, 2022 3:29 am
I have a basic code writing on a SD card with a method called appendToIt that I call at the end o setup several times and it works no problem.
But when I try to call the same method (just once) in the loop
if (firstTime) {
Serial.println(" try print in loop first time ");
firstTime = false;
appendToIt();
delay(3000);
while (true)
I get a Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
The strange thing is that the same method works in setup many times but not even one time in the loop so it appears to be a bug.
The code follows and after that the console output.
// copied from SD_TEST.ino in examples
#include "FS.h"
#include "SD.h"
#include "SPI.h"
//these are defined in FluidNC config for the MKS DLC board
const int misoPin = 12;
const int mosiPin = 13;
const int sckPin = 14;
const int csPin = 15;
unsigned long startTime = millis(); //in ms
String stringLogFileName = "/log" + getFormatedTimeSinceStart() + ".txt";
const char *fileName = stringLogFileName.c_str(); //todo in one line
// XXX This should be a configuration parameter of the SPI bus
const int32_t SPIfreq = 4000000;
unsigned long zeroTimeMillis = 0; //in ms
void createDir(fs::FS &fs, const char *path) {
	Serial.printf("Creating Dir: %s\n", path);
	if (fs.mkdir(path)) {
		Serial.println("Dir created");
		Serial.println("mkdir failed");
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
	Serial.printf("Listing directory: %s\n", dirname);
	File root = fs.open(dirname);
	if (!root) {
		Serial.println("Failed to open directory");
		return;
	if (!root.isDirectory()) {
		Serial.println("Not a directory");
		return;
	File file = root.openNextFile();
	while (file) {
		if (file.isDirectory()) {
			Serial.print("  DIR : ");
			Serial.println(file.name());
			if (levels) {
				listDir(fs, file.name(), levels - 1);
			Serial.print("  FILE: ");
			Serial.print(file.name());
			Serial.print("  SIZE: ");
			Serial.println(file.size());
void removeDir(fs::FS &fs, const char *path) {
	Serial.printf("Removing Dir: %s\n", path);
	if (fs.rmdir(path)) {
		Serial.println("Dir removed");
		Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path) {
	Serial.printf("Reading file: %s\n", path);
	File file = fs.open(path);
	if (!file) {
		Serial.println("Failed to open file for reading");
		return;
	Serial.print("Read from file: ");
	while (file.available()) {
		Serial.write(file.read());
	file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
	Serial.printf("Writing file: %s\n", path);
	File file = fs.open(path, FILE_WRITE);
	if (!file) {
		Serial.println("Failed to open file for writing");
		return;
	if (file.print(message)) {
		Serial.println("File written");
		Serial.println("Write failed");
	file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
	Serial.printf("Appending to file: %s\n", path);
	File file = fs.open(path, FILE_APPEND);
	if (!file) {
		Serial.println("Failed to open file for appending");
		return;
		Serial.println("Message appended");
		Serial.println("Append failed");
	file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
	Serial.printf("Renaming file %s to %s\n", path1, path2);
	if (fs.rename(path1, path2)) {
		Serial.println("File renamed");
		Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char *path) {
	Serial.printf("Deleting file: %s\n", path);
	if (fs.remove(path)) {
		Serial.println("File deleted");
		Serial.println("Delete failed");
void testFileIO(fs::FS &fs, const char *path) {
	static uint8_t buf[512];
	size_t len = 0;
	uint32_t start = millis();
	uint32_t end = start;
	if (file) {
		len = file.size();
		size_t flen = len;
		start = millis();
		while (len) {
			size_t toRead = len;
			if (toRead > 512) {
				toRead = 512;
			file.read(buf, toRead);
			len -= toRead;
		end = millis() - start;
		Serial.printf("%u bytes read for %u ms\n", flen, end);
		file.close();
	if (!file) {
		return;
	size_t i;
	start = millis();
	for (i = 0; i < 2048; i++) {
		file.write(buf, 512);
	Serial.printf("%u bytes written for %u ms\n", 2048 * 512, end);
	file.close();
	//SPI.begin(sckPin, misoPin, mosiPin);  // CS is defined by each device
	SPIClass hspi = SPIClass(HSPI); //HSPI has the 12-15 pins already configured // actually a reference
	if (!SD.begin(csPin, hspi, SPIfreq, "/sd", 2)) { //copied from Fluid SDCard.cpp //if (SD.begin(csPin, SPI, SPIfreq, "/sd", 2)) {
		//if(!SD.begin(csPin)){  //copied from Fluid SDCard.cpp //if (SD.begin(csPin, SPI, SPIfreq, "/sd", 2)) {
		Serial.println("Card Mount Failed");
		return;
	uint8_t cardType = SD.cardType();
	if (cardType == CARD_NONE) {
		Serial.println("No SD card attached");
		return;
	Serial.print("SD Card Type: ");
	if (cardType == CARD_MMC) {
		Serial.println("MMC");
	} else if (cardType == CARD_SD) {
		Serial.println("SDSC");
	} else if (cardType == CARD_SDHC) {
		Serial.println("SDHC");
		Serial.println("UNKNOWN");
	uint64_t cardSize = SD.cardSize() / (1024 * 1024);
	Serial.printf("SD Card Size: %lluMB\n", cardSize);
	listDir(SD, "/", 0);
//	createDir(SD, "/adriandir");
//	listDir(SD, "/", 0);
//	removeDir(SD, "/mydir");
//	listDir(SD, "/", 2);
//	writeFile(SD, "/hello.txt", "Hello ");
//	appendFile(SD, "/hello.txt", "World!\n");
//	readFile(SD, "/hello.txt");
//	deleteFile(SD, "/foo.txt");
//	renameFile(SD, "/hello.txt", "/foo.txt");
//	readFile(SD, "/foo.txt");
//	testFileIO(SD, "/test.txt");
//	Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
//	Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
	//time stuff
	Serial.println(" Starting a log named: " + String(fileName));
	writeOnce();
	appendFile(SD, fileName, "World!\n");
	for (int i = 0; i < 2; i++) {
		appendToIt();
		delay(2000);
	Serial.println("Finished Logging");
boolean firstTime = true;
	if (firstTime) {
		firstTime = false;
		appendToIt();
		delay(3000);
		while (true)
void writeOnce() {
	Serial.println(" in writeOnce");
	File myFile = SD.open(fileName, FILE_WRITE); // create or open a file for writing
	Serial.println(" after: " + getFormatedTimeSinceStart());
	if (myFile) {
		myFile.println(millis() - zeroTimeMillis); //last item of the CSV entry is the current time, saving this with a carriage return to terminate CSV row
		delay(1000); //wait around 1 second and then do it all again!
		myFile.close(); //close the SD card file
		delay(1000);
	} else //if the SD card DOES NOT WRITE, then
		Serial.println("the SD card DOES NOT WRITE");
	delay(2000);
void appendToIt() {
	Serial.println(" in appendToIt");
	File myFile = SD.open(fileName, FILE_APPEND); // create or open a file for writing
	//appendFile(SD, fileName, "World!\n");
	if (myFile) {
		delay(1000);
	delay(2000);
String getFormatedTimeSinceStart() {
	unsigned long time = (unsigned long) ((millis() - startTime) / 1000); //finds the time since last print in secs
	return formatTime(time);
String formatTime(unsigned long time) {
	String result = "";
	int hours = (unsigned long) (time / 3600);
	if (hours > 0) {
		result = +hours;
		result += ("h ");
	result += ((unsigned long) (time % 3600) / 60);
	result += ("m ");
	result += (time % 60);
	result += ("s");
	return result;
console
SD Card Type: SDHC
SD Card Size: 15193MB
Listing directory: /
DIR : /System Volume Information
FILE: /log0m 0s.txt SIZE: 0
Starting a log named: /log0m 0s.txt
in writeOnce
after: 0m 0s
after: 0m 0s
Appending to file: /log0m 0s.txt
Message appended
in appendToIt
after: 0m 4s
after: 0m 4s
in appendToIt
after: 0m 10s
after: 0m 10s
Finished Logging
in appendToIt
Core 1 register dump:
PC : 0x400f2b6e PS : 0x00060b30 A0 : 0x800d1b0e A1 : 0x3ffb1b90
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00060920 A7 : 0x00000000 A8 : 0x80087130 A9 : 0x3ffb1ba0
A10 : 0x00000003 A11 : 0x00060b23 A12 : 0x00060b20 A13 : 0x00000001
A14 : 0x00060923 A15 : 0x00000000 SAR : 0x00000011 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000018 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffffc
ELF file SHA256: 0000000000000000
Backtrace: 0x400f2b6e:0x3ffb1b90 0x400d1b0b:0x3ffb1bb0 0x400d1e11:0x3ffb1be0 0x400d2365:0x3ffb1c10 0x400e93c2:0x3ffb1c50 0x400e82f2:0x3ffb1c70 0x400e9779:0x3ffb1ca0 0x400ea7e3:0x3ffb1cc0 0x4000bd9f:0x3ffb1ce0 0x40001191:0x3ffb1d00 0x400d87d9:0x3ffb1d20 0x400d84ea:0x3ffb1d90 0x400d838e:0x3ffb1db0 0x400d83b4:0x3ffb1de0 0x400d3542:0x3ffb1e00 0x400d3a77:0x3ffb1e30 0x400d3d3d:0x3ffb1e70 0x400d31bb:0x3ffb1ef0 0x400d1435:0x3ffb1f20 0x400d158b:0x3ffb1f90 0x400d6675:0x3ffb1fb0 0x40086269:0x3ffb1fd0
Rebooting...
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x3b (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
SD Card Type: SDHC
and continues rebooting
Many thanks,
Adrian
chenduoduo
Re: Is this a bug Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Postby chenduoduo » Thu Feb 01, 2024 9:19 am
hi, did you fixed this problem? I got the same exception
Users browsing this forum: No registered users and 17 guests
