Debuggung not working, VSCode 1.49.2 Espressif Extension 0.5.1
Posted: Wed Sep 30, 2020 1:04 am
by ennogrue
On a fresh Windows 10 2004 I installed VSCode 1.49.2 with Espressif Extension 0.5.1., plain successful onboarding.
I am using ESP Wrover Kit 4.1.
With the blink example I can build and flash the target, the console output of the blink application is fine.
But I cannot debug:
F5 doesn't work.
When starting the openocd server I get:
Open On-Chip Debugger v0.10.0-esp32-20191114 (2019-11-14-14:19)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
WARNING: boards/esp32-wrover.cfg is deprecated, and may be removed in a future release.
If your board is ESP32-WROVER-KIT, use board/esp32-wrover-kit-1.8v.cfg instead.
Info : Configured 2 cores
❌ Error: type 'esp32' is missing virt2phys
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
What does the error "type 'esp32' is missing virt2phys" mean and how can I avoid it?
My settings.json:
"C_Cpp.clang_format_style": "Visual Studio",
"editor.formatOnSave": false,
"[cpp]": {
"editor.quickSuggestions": true
"[c]": {
"C_Cpp.intelliSenseEngineFallback": "Enabled",
"idf.adapterTargetName": "esp32",
"idf.openOcdConfigs": [
"interface/ftdi/esp32_devkitj_v1.cfg",
"board/esp32-wrover.cfg"
"idf.portWin": "COM7",
"idf.toolsPathWin": "C:\\Users\\eg\\.espressif"
How can I make debugging work?
Regards
ennogrue
