strlen function to empty char* causes reboot
Posted: Wed Aug 07, 2019 3:31 pm
by gerrikoio
Whether right or wrong, this code is handled by Arduino UNO and Arduino MKR without crashing. It tells me strlen = 1.
With my ESP32 it causes continuous reboot.
char *thisCharPntr;
void setup() {
  Serial.begin(115200);
  Serial.print("Char length: ");
  Serial.println(strlen(thisCharPntr));
void loop() {
Re: strlen function to empty char* causes reboot
Posted: Thu Aug 08, 2019 12:00 am
by ESP_Angus
Hi gerrikoio,
This is not a bug in ESP-IDF or Arduino-ESP32.
Because thisCharPntr is a static variable it's initialized to NULL. Evaluating strlen(NULL) involves dereferencing a NULL pointer, and dereferencing a NULL pointer is undefined behaviour in C. (strlen is a C function.)
Undefined behaviour means the implementation is allowed to do whatever it wants. Most computers (including ESP32) will crash. Possibly some implementations don't crash and will instead do something else.
C11 added a new function strlen_s() which has defined behaviour if the pointer is NULL (it returns 0).
Suggesting adding a null-check in your code if you need to verify that thisCharPntr is not-null before calling strlen(NULL)
You can read more about this here: https://stackoverflow.com/a/5796686/1006619
Posted: Thu Aug 08, 2019 10:20 am
by gerrikoio
Thanks. Your explanation is very clear and most helpful. :D
