I'm using the IDF 4.4 with ADF on a ESP32-LyraTD-MSC_A V2.2 and am facing a problem. After opening a HFP connection to a mobile device I want to use the hfp client functions like esp_hf_client_answer_call, esp_hf_client_dial. Unfortunately they stop working after 1 or 2 uses. I mapped the Buttons on the Board to the functions so I can easily try it out. This happens both in the pipeline_a2dp_sink_and_hfp example from the ADF and in a own program that ONLY uses HFP.
I edited the Button code in the example and my own program to execute HFP functions on press
if ((int) msg.data == get_input_play_id()) {
ESP_LOGI(TAG, "[ * ] ANSWER Call");
esp_err_t err = esp_hf_client_answer_call();
if (err != ESP_OK) {
ESP_LOGW(TAG, "[ * ] ANSWER Failed");
} else if ((int) msg.data == get_input_set_id()) {
ESP_LOGI(TAG, "[ * ] REJECT Call");
esp_err_t err = esp_hf_client_reject_call();
ESP_LOGW(TAG, "[ * ] REJECT Failed");
} else if ((int) msg.data == get_input_volup_id()) {
ESP_LOGI(TAG, "[ * ] VOL 16");
esp_err_t err = esp_hf_client_volume_update(ESP_HF_VOLUME_CONTROL_TARGET_SPK, 16);
ESP_LOGW(TAG, "[ * ] VOL 16");
} else if ((int) msg.data == get_input_voldown_id()) {
ESP_LOGI(TAG, "[ * ] VOL 0");
esp_err_t err = esp_hf_client_volume_update(ESP_HF_VOLUME_CONTROL_TARGET_SPK, 0);
ESP_LOGW(TAG, "[ * ] VOL 0 Failed");
} else if ((int) msg.data == get_input_mode_id()) {
ESP_LOGI(TAG, "[ * ] CALL");
esp_err_t err = esp_hf_client_dial("XXXXXX"); // removed number
ESP_LOGW(TAG, "[ * ] CALL Failed");
- Start ESP
- Connect with mobile device
- Press "Mode" button to init call to number
- Press "Set" button to stop call
- Repeat as often as you like
- Start ESP
- Doesn't respond to the buttons anymore -> Can't reject calls or init calls anymore
I (19731) HFP_STREAM_C: --Inband ring state Provided
D (19741) BT_BTC: btc_transfer_context msg 0 10 1 0x0
D (19741) BT_BTC: btc_thread_handler msg 0 10 1 0x0
D (26651) BT_BTC: btc_transfer_context msg 0 8 0 0x3ffbd008
D (26651) BT_BTC: btc_thread_handler msg 0 8 0 0x3ffdfff0
D (26651) BT_BTC: btc_alarm_handler act 0
D (26661) BT_BTC: btc_transfer_context msg 1 7 31 0x3ffdb4f0
D (26661) BT_BTC: btc_thread_handler msg 1 7 31 0x3ffe37f4
D (26661) BT_BTC: btc_dm_upstreams_cback ev: 31
D (26671) BT_BTC: BTA_DM_PM_MODE_CHG_EVT mode:2
I (32831) HFP_EXAMPLE: [ * ] CALL
D (32831) BT_BTC: btc_transfer_context msg 0 17 9 0x3ffca818
D (32831) BT_BTC: btc_thread_handler msg 0 17 9 0x3ffe3dc0
D (33461) BT_BTC: btc_transfer_context msg 1 7 31 0x3ffdb4f0
D (33461) BT_BTC: btc_thread_handler msg 1 7 31 0x3ffe37f4
D (33461) BT_BTC: btc_dm_upstreams_cback ev: 31
D (33471) BT_BTC: BTA_DM_PM_MODE_CHG_EVT mode:0
D (33801) BT_BTC: btc_transfer_context msg 1 17 15 0x3ffdb520
D (33801) BT_BTC: btc_thread_handler msg 1 17 15 0x3ffdfff0
I (33801) HFP_STREAM_C: APP HFP event: AT_RESPONSE
I (33811) HFP_STREAM_C: --AT response event, code 0, cme 0
E (33921) BT_BTM: btm_sco_connected, handle 180
D (33921) BT_BTC: btc_transfer_context msg 1 17 5 0x0
D (33921) BT_BTC: btc_thread_handler msg 1 17 5 0x0
I (33921) HFP_STREAM_C: APP HFP event: AUDIO_STATE_EVT
I (33931) HFP_STREAM_C: --Audio state connected
I (33941) HFP_EXAMPLE: bt_app_hf_client_audio_open type = 0
I (37141) HFP_EXAMPLE: [ * ] REJECT Call
D (37141) BT_BTC: btc_transfer_context msg 0 17 14 0x0
I (43021) HFP_EXAMPLE: [ * ] REJECT Call
D (43021) BT_BTC: btc_transfer_context msg 0 17 14 0x0
I (44341) HFP_EXAMPLE: [ * ] REJECT Call
D (44341) BT_BTC: btc_transfer_context msg 0 17 14 0x0
I (45981) HFP_EXAMPLE: [ * ] REJECT Call
D (45981) BT_BTC: btc_transfer_context msg 0 17 14 0x0
D (48761) BT_BTC: btc_transfer_context msg 1 17 7 0x0
D (48771) BT_BTC: btc_transfer_context msg 1 17 10 0x3ffdb500
I (55461) HFP_EXAMPLE: [ * ] CALL
D (55461) BT_BTC: btc_transfer_context msg 0 17 9 0x3ffca818
D (56131) BT_BTC: btc_transfer_context msg 1 7 31 0x3ffdb4f0
I (57741) HFP_EXAMPLE: [ * ] CALL
D (57741) BT_BTC: btc_transfer_context msg 0 17 9 0x3ffca818
Is the btc_task that should handle the transferred messages somehow frozen?
What might be the reason that the btc_ layer stops handling messages?
Is there a misconception I have about the esp_hf_client_* functions?
How to debug something like that?
Would be awesome if anybody had some kind of input!
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
