Sudden build problems
Posted: Thu Mar 28, 2019 11:14 am
Environment
- IDF version: Current master and release/v3.2
- Build System: [Make]
- Compiler version: (crosstool-NG crosstool-ng-1.22.0-80-g6c4433a5) 5.2.0
- Operating System: [Windows]
Problem Description
Suddenly building stopped working. We have tried checking out a compleately clean esp-idf and a new https://docs.espressif.com/projects/esp ... hain-setup. We have tried both master and release/v3.2.
IDF_PATH is set correctly.
This is from running make in the example/wifi/scan
This is only a problem on one specific computer where building did work before. This is probably not anything related to the esp-idf, but instead Windows/msys.
I cannot figure out what to do and I'm not very keen on having to whipe the computer due to this.
Does anyone have any idea?
Thanks alot
Problem Description
/bin/sh: -c: line 0: syntax error near unexpected token `('
/bin/sh: -c: line 0:` MAKEFLAGS="" CC=C:\Program Files (x86)\CMake\bin LD=ld \'
python requirements from /c/Users/me/esp-idf/requirements.txt are satisfied
Thanks alot
