How to obtain length of binary COMPONENT_EMBED_FILES
papaluna
Postby papaluna » Tue Feb 26, 2019 8:04 am
What is the simplest way to obtain the length in bytes of an embedded binary file when using https://docs.espressif.com/projects/esp ... inary-data?
Is an attribute available which returns the length or do I have to compute it myself?
This is the way I do it right now:
COMPONENT_EMBED_FILES := kafka_status_ok.message
extern const uint8_t kafka_status_ok_message_start[] asm("_binary_kafka_status_ok_message_start");
extern const uint8_t kafka_status_ok_message_end[] asm("_binary_kafka_status_ok_message_end");
int len_buffer = sizeof(uint8_t) * (kafka_status_ok_message_end - kafka_status_ok_message_start);
Paul.
ESP_igrr
Re: How to obtain length of binary COMPONENT_EMBED_FILES
Postby ESP_igrr » Tue Feb 26, 2019 10:05 am
The way you are doing this now seems to be the correct one. I don't think there is any better option when using just COMPONENT_EMBED_FILES without any extra logic.
(extra logic would be: determine size of the file at Make run time, store it as a variable, add -DMY_FILE_LEN=$(length_var) to CPPFLAGS...)
papaluna
Postby papaluna » Tue Feb 26, 2019 10:12 am
Thanks.
Paul.
FiwiDev
Postby FiwiDev » Thu Jan 04, 2024 10:43 pm
I was digging through a compiled MAP output (trying to find the actual handles the compiler used for the embedded files), and noticed that there appears to be a "size" attribute also provided. See below...
_binary_web_index_htm_end                         .pio/build/esp32dev/index.htm.txt.o
                                                  .pio/build/esp32dev/src/wifi.cpp.o
_binary_web_index_htm_size                        .pio/build/esp32dev/index.htm.txt.o
_binary_web_index_htm_start                       .pio/build/esp32dev/index.htm.txt.o
_binary_web_script_js_end                         .pio/build/esp32dev/script.js.txt.o
_binary_web_script_js_size                        .pio/build/esp32dev/script.js.txt.o
_binary_web_script_js_start                       .pio/build/esp32dev/script.js.txt.o
_binary_web_style_css_end                         .pio/build/esp32dev/style.css.txt.o
_binary_web_style_css_size                        .pio/build/esp32dev/style.css.txt.o
_binary_web_style_css_start                       .pio/build/esp32dev/style.css.txt.o
I'm not well versed in the binutils, i.e. trying to figure out if that symbol is actually mapped to a memory address, what size the symbol is (assuming 32-bit?), and what value it is. Tried defining an "asm("")" to reference the corresponding "*_size" entry to a size_t, but it just crashes the ESP32 every time I try to access it.
I mean, doing "end - start" is one way to get the length--but heck, if there's a better way...what's the trick?
Users browsing this forum: jesper and 91 guests
