ESP-Now: Maximum Peer Number
Posted: Fri Feb 08, 2019 11:21 am
Hello, I'm trying to use ESP-Now with 10 encrypted peers, it should be possible according to
https://www.espressif.com/sites/default ... ide_en.pdf
"Limited encrypted peers. 10 encrypted peers at the most are supported in Station
mode; 6 at the most in SoftAP or SoftAP + Station mode. "
I'm using WIFI_MODE_STA but can only add 6 peers.
In esp_now.h there is
#define ESP_NOW_MAX_ENCRYPT_PEER_NUM 6 /*!< Maximum number of ESPNOW encrypted peers */
I set it at 10 but I've got no success.
What should be done to overcome this limit? Ideally it would be better to even have a bigger number of peers, even 10 would be quite small and I see no reason for this. Is it a RAM issue?
Regards.
Regards.
