nvs_set_blob issue with UART interrupt enabled
Posted: Wed Jan 30, 2019 11:17 am
We have an application running both BLE and WiFi. MQTT is used to communicate with server. It uses UART read interrupt to communicate with a third party device.
We are trying to read/write data in nvs memory. NVS read is working fine but while writing it gets stuck and control never returns back from nvs_set_blob.
Disabling UART interrupt before nvs write had no effect. Calling uart_driver_delete seems to be working. Is there any other way to do this?
ESP IDF: v3.1-dirty
Below is the UART configuration used
Partition table
ESP IDF: v3.1-dirty
uart_config_t uart_config = {
.baud_rate = 4800,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_EVEN,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE};
uart_param_config(UART_NUM_2, &uart_config);
uart_set_pin(UART_NUM_2, 17, 16, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_driver_install(UART_NUM_2, 1024* 2, 0, 0, NULL, 0);
uart_set_line_inverse(UART_NUM_2, UART_INVERSE_TXD | UART_INVERSE_RXD);
uart_isr_free(UART_NUM_2);
uart_isr_register(UART_NUM_2, uart2_isr, NULL, ESP_INTR_FLAG_IRAM, &uart2_intr_handle);
otadata, data, ota, 0xd000, 0x2000,
phy_init, data, phy, 0xf000, 0x1000,
factory, app, ota_0, 0x10000, 0x178000,
ota_1, app, ota_1, , 0x178000,
nvs, data, nvs, , 0x10000,
